Change a ring gear and not the pinion?
Morning,
Can the ring gear be changed without changing the pinion too?
![]() 76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
Re: Change a ring gear and not the pinion?
No
No
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
![]() Join Date: Jul 2009
Can you do it? Yes! Will it survive...Absolutely not!
I'm not sure it will even assemble (much less rotate).
K
#6 | |
If it is the same ratio, you can get it assembled, but it won't last long....and there would be no point to that anyway. You couldn't possibly destroy the ring w/o hurting the pinion too, so there is no reason to split a set anyway.
You can review the site's rules here. Quote:
Bad planning on your part does not necessarily constitute an instant emergency on my part.... The great thing about being a pessimist is that you are either pleasantly surprised or right. ![]() |
well I dont suggest to do it but It does work I broke the pinion gear on my wood hauler. I took a used pinion gear the same ratio, bead blasted both gears and set them up and completely painted them with anti seize. I will say it was a little harry at first but it has been working ok so far.
#8 | |
You are correct. Gear sets are "lapped" together at the factory and become a single unit at that point. You can't (shouldn't) split them after that point. K
dang its hot
can it be done? yes. should it be done? no.
That's what i figured but wanted to make sure. Thanks guys
