11-10-2009, 03:34 PM | #1 |
Just Not Low Enough!
Rear Air-bag Question
ok guys, have a few questions, i am doing the rear airbags on my '67 SWB, no notch, putting the bag in the stock spring location, heres the problem, the bag studs are too short to get enough threads through the frame & cross member to let the nut bite. Hence the stripped stud, cause i wasnt paying attention.
so i am accessing my options and this is what i have come up with.. 1. take out factory cross member brace and run that setup. (any downfall?) would be temporary till i can build the bridge. 2. or just dive in and remove entire cross member and build bridge as i would like to eventually lay frame. Any comments, suggestions, or pictures would be greatly appreciated. Thanks CM
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. Last edited by BAGNDRAGIT; 11-10-2009 at 03:55 PM. Reason: Wront title |
11-10-2009, 07:19 PM | #2 |
67-72 parts collector,…
Re: Stripped Air-bag Stud
Buy a Slam Specialties RE-7 bag (or like kind bag) that will take a bolt.
Alot easier than rebuilding your frame.
11-10-2009, 07:22 PM | #3 |
low n' slo
thats what i would do. that would be a lot of work just to save a bag..
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
11-10-2009, 07:28 PM | #4 |
Is there any thread left on the stud that is usable?
11-10-2009, 09:12 PM | #5 |
yeah there is, and i would love to buy new bags, but funds are tight, looking for a cheap way to make a quick fix. i means its eight rivets, and with a air hammer its no work.
and i do plan on notching with a bridge eventually so. Thanks for the input guys! CM
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. |
11-10-2009, 09:15 PM | #6 |
I think removing that crossmember without replacing it with something else would not be wise.
11-10-2009, 09:20 PM | #7 |
Go to your local hardware store and get a threaded rod connector, then you can lengthen your stud. However I have no idea if it would be strong enough or if you would have room. Just a thought from an old hardware store owner. Or what about a shock extender would that work ?
11-10-2009, 10:33 PM | #8 | |
the yellow box highlights the support i am talking about (btw this pic is from the bottom of the frame)
NEED ELECTRICAL HELP? ASK ME! 67-72 Full Wiring Diagrams Lots Of Info, TAKE A LOOK 1967 Chevy C-10 Shortbox Bagged 327 4spd Previous: 1971 Chevy C-10 Short Sep I6 Auto (Traded) 1973 Chevy C-20 *THE REDNECK BATTLE TRUCK* 2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P. 1969 Volkswagen Bug This is my first meeting, I have a horsepower problem. Last edited by BAGNDRAGIT; 11-10-2009 at 10:34 PM. |
11-10-2009, 11:00 PM | #9 |
low n' slo
is that the original frame or did you weld a plate to bolt the bag to?
11-10-2009, 11:04 PM | #10 |
thats not my frame (should have mentioned that, i only used the photo from a fellow board member to illustrate what i was talking about)
my frame is bone stock in the rear. rivets and all.
11-10-2009, 11:20 PM | #11 |
I would still swap out the bag,...
11-10-2009, 11:28 PM | #12 |
I'll tell you what my experience has been when "trying" to take the cheap route. Its ususally cheaper in the long run just to get the right parts the first time, and be done with it. I've spend more money trying to makke something fit or work after I accidently messed something up, I end up still going to get another part or correct part to fix it.
Like lolife99 says get a different bag. Thats my .02 worth.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! Last edited by BarryB; 11-10-2009 at 11:30 PM. |
11-10-2009, 11:34 PM | #13 |
alright so the general consensus is swapping to an RE7 or similar, with a bolt style mount, instead of stud.
well off to make some side money... still curious if anyone has removed that support and had issues.. thats everyone.
11-10-2009, 11:41 PM | #14 | |
Is the stud theaded into the bag plate or is it staked in I've seen em both ways if it's threaded unscrew it and screw in a longer stud if it's staked in then well I was never here.....
1965 GMC shortwide big window 1969 Chevy C20 long (for now) 2005 Silverado 2500HD Crew Cab Quote:
11-10-2009, 11:49 PM | #15 |
hmmm. good point, i will check that in the A.M. Thanks!
11-11-2009, 01:46 AM | #16 | |
11-11-2009, 11:13 AM | #17 |
You can remove that brace with no problems, there are other crossmembers that will support the frame. However, I don't understand how that will contribute to laying frame, I'd say buy the doms or slams with the bolt hole.
11-11-2009, 12:04 PM | #18 | |
and yeah i think i am going to go buy them.
11-11-2009, 07:04 PM | #19 |
another alternitive would be to shorten the stud, then weld on addtitional thread (all thread). My tig welder gets me out of this kind of trouble all the time.
The kid Build threads: 51 Jimmy http://67-72chevytrucks.com/vboard/s...d.php?t=154951 http://67-72chevytrucks.com/vboard/s...d.php?t=219902 http://www.classictrucks.com/feature...uck/index.html 68 C10 http://67-72chevytrucks.com/vboard/s...ad.php?t=50348 |
11-11-2009, 10:41 PM | #20 |
this just reinforces how much i need a welder!!
11-11-2009, 11:30 PM | #21 |
Man with welder can build anything. then all the other gotstahave tools come into play. Then you'll have to have a bigger tool box to keep them all in, oh then there isn't enough room so a bigger garage is a must. the trickle down effect. OH you better get several side jobs. playing with old stuff isn't cheap.
*We could learn a lot from crayons... Some are sharp; some are pretty;and some are dull. Some have weird names; and all are different colours;but they all have to live in the same box. * You may be only one person in the world, But you may also be the world to one person. * Some mistakes are too much fun to only make once. Two rules in life. 1. Never sweat the small stuff! 2. Everything is small stuff! |
11-12-2009, 12:02 AM | #22 | |
