Old 11-10-2009, 05:39 PM   #1
Tkmadone
Power ram to saginaw conversion
So my power ram assisted steering on my '67 C20 blew this morning so I would like to just install the later model saginaw box. My question is whether I'll need to change anything else in the steering system like the drag link or pitman arm or if I can just basically remove all the ram stuff and install the new box?
Thanks!
Tkmadone is offline   Reply With Quote
Old 11-10-2009, 07:02 PM   #2
cdowns
cdowns's Avatar
Re: Power ram to saginaw conversion
i think you need to change the center link tierod ends idler arm and spindles for the conversion
Old 11-12-2009, 12:52 AM   #3
oldspowered67C10
I think you can use all the stock linkage but be aware that just bolting the new box to the frame isnt a ideal set-up, the 68 and up frames were bumped in to clear the p/s box larger sector shaft. If you just bolt it up, centered for the center link will not be centered for the box and the truck will either scrub tires on tight turns or wander on center depending on how you overcome the problem, Ill post a pic of what I did to overcome the problem.
oldspowered67C10 is offline   Reply With Quote
Old 11-12-2009, 12:24 PM   #4
Tkmadone
Cool! Thanks for the info!
Old 11-12-2009, 01:25 PM   #5
screamin_c10
I dun gradjiated collij!!!
screamin_c10's Avatar
You will need a new draglink as the old one has the control valve stud mounted to it. You will also need the pitman arm from the "new" saginaw box as the old style piman arm is totally different.
The pressure port on the pump is flared differently and has a reducer in it, you will need this piece or a later model pump
Due to yhe length and fittings, new hoses will be needed.
The outer tie rod ends on the 67 C20 are one of a kind and would not thread into the adjuster sleeves on the later model inner tie rod ends that are needed to fit the later model draglink....
Can you tell I just did this exact thing 1 month ago....very frustrating for such a simple swap....dont forget to dimple the frame or buy a custom bracket to provide clearance for the new gear box....
I ended up having to replace everything from Outer tie rod end to outer tie rod end with parts from my 72 C10 and 73-87 pieces...but it works and I drive the dog snot out of her now.....
screamin_c10 is offline   Reply With Quote
Old 11-12-2009, 05:14 PM   #6
ges55
BLACK SATIN
ges55's Avatar
You can get new & remanufactured control valves (if that is your problem) on Ebay & at parts stores. It is the same one used on the 63-82 Corvettes. Mine lasted 42 years before I had to replace it. Just a thought. There is also a guy that sells instructions for using later model systems on the older trucks. He is called the bondobandito & sells them for $15.00.
67 C10 Fleetside LWB-283, 3 on the tree,power assisted steering, father-in-law bought it new
67 C20 Fleetside LWB-'85 305 V8 (original was 250 6 cyl), Holley 600 carb, full length Hedman headers, dual exhaust behind the back wheels, 4 spd , manual steering
85 C10 Silverado- 305ci
ges55 is offline   Reply With Quote
