Old 11-10-2009, 06:17 PM   #1
Aaron104
350 heads on a 305 block
can you run 350 heads on a 305 block? if you can what are the pros and cons?
Aaron104 is offline   Reply With Quote
Old 11-10-2009, 06:25 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: 350 heads on a 305 block
can't do it, the valves will hit the cylinder walls. (won't open)
Old 11-10-2009, 07:34 PM   #3
truckster
truckster's Avatar
That would definitely be a con!
truckster is offline   Reply With Quote
Old 11-10-2009, 09:50 PM   #4
1-PU70
1-PU70's Avatar
Im running 350 heads on a 307.
1970 CST/10 402,700R4,3:73 posi,AC,PS,PB,TLT,PW,Buckets with heaters
1-PU70 is offline   Reply With Quote
Old 11-11-2009, 12:16 PM   #5
turp mcspray
turp mcspray's Avatar
Depends on the valve size.
305 has such a small bore size, that the large chamber head will drop the compression.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 11-11-2009, 04:24 PM   #6
71tahoe
71tahoe's Avatar
Even though it's 2 cubic inches, 307 std bore is 3.875 and 305 is 3.736.
71tahoe is offline   Reply With Quote
Old 11-11-2009, 11:17 PM   #7
pritch
pritch's Avatar
"I got 350 heads on a 305 engine
I get ten miles to the gallon
I ain't got no good intentions"
What, no Drive By Truckers fans here?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 11-12-2009, 08:34 AM   #8
rscam
I think they will physically fit. But the valves are so close to the cylinder wall they call it shrouding the valve. When the valve open the part that is close to the wall won't let any fuel in and vise versa for the exhaust.
rscam is offline   Reply With Quote
Old 11-12-2009, 11:42 PM   #9
silverstreak
I've been doing a little research on how to get a little more power from my 305. I've read some articles on swapping on some L30 "059" vortec heads (1996 - 2002 305) on an older block. It seems to be a good swap, but needs a "vortec" style intake as the intake mounting bolts are different and uses centerbolt valve covers. They also use specific rail type rocker arms and are limited to .430 max valve lift due to the retainers contacting the valve guides. Edelbrock makes a performer intake whick seems reasonably priced. They also don't have the exhaust crossover to keep the intake / carb heated in cold weather. So, I'm still on the fence on that decision.
silverstreak is offline   Reply With Quote
Old 11-13-2009, 12:05 AM   #10
Richard8971
Still livin the "dream" in '54
Richard8971's Avatar
I have heard you can run 305 heads on a 350 but not sure on the other way around...
Hmmmm.
D
Current build. 1954 Chevrolet 3800 "Ella" SOLD!
My '67 stepper "Tangerine Dream"
"Anything worth doing is worth doing right" James Dean
“When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.”
Sherlock Holmes
"There is no spoon." Neo
Richard8971 is offline   Reply With Quote
Old 11-13-2009, 01:20 AM   #11
joedoozer
is Certifiable
joedoozer's Avatar
Find out what heads you have on the motor now, see if they are anything worth using. 1.94 intakes and a 64 or 67cc chamber will be just fine for a 305. Put a decent cam in it, something with lift around .430 to .450. The smaller bore of the 305, and the smaller intake runners will limit just how well it breathes. So duration would be a little more important than lift in your case. I would guess .
Best bet is get as much information as you can from your vehicle. Weight, rearend gears, transmission, converter stall, exactly what the engine is (compression and so on). And call a tech line of some camshaft manufacturers. They can run the numbers and help you out. You will get some really good info from this site, and from tech support. But collect as much information as you can before you spend your hard earned money.
1972 Chevy C10 LWB 350 Auto
Blue with a white roof.
joedoozer is offline   Reply With Quote
Old 11-13-2009, 03:21 AM   #12
custom72c20
custom72c20's Avatar
You are correct. I have seen it done before.
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
