Old 11-10-2009, 07:15 PM   #1
292farmer
292farmer's Avatar
need help with axle ratio
i have a 1972 gmc c20 292i6 4 spd manual reg cab lwd i need help trying to figure out what my gear ratio is, i am told that it was a 4.56 by original owner i found these numbers and letters, here they are sorry some pics are upside down.
c34950 2 60-3b it has ten bolts im pretty sure its a dana 60 hence the the 60 num
i used a formula to figure out my ratio using my rpms and mph and i came up with 5.3? i thought maybe 5.13? but didnt see it as option for dana 60
292farmer is offline   Reply With Quote
Old 11-10-2009, 07:17 PM   #2
msgross
msgross's Avatar
Re: need help with axle ratio
I always suggest to taking the diff cover off, look at the numbers on the ring gear (41:11 ratio = 3.73, etc..) and put some fresh oil when you install the cover again...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 11-10-2009, 07:31 PM   #3
292farmer
292farmer's Avatar
yeah that was the next step i was just curious to see if what i could figure out off the numbers did the dana have posis? cuz it has in sane traction and neither wheel will spin much before they both seem to match each other
Old 11-10-2009, 07:33 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
I'm guessing the one thing that might be skewing your data is that most speedo's and tach's in these trucks are not 100% accurate (unless you're running an aftermarket tach). In mine, the speedo was off by around 12%. the tach was off by 20%!!!! So find a way to calibrate yoru gauges and try it again.
69GMCLonghorn is offline   Reply With Quote
Old 11-10-2009, 08:18 PM   #5
msgross
msgross's Avatar
gmc's did have dana60's so you're probably right with that one, would need more pics though...
Once you open it up and snap some pics you will see what it has in it...
The Garage:
Old 11-10-2009, 08:30 PM   #6
292farmer
292farmer's Avatar
if i remember ill take more pics tomm, if im not to tired and can afford the gasket and oil after work maybe ill peel off cover too. as for the tach it was a sunpro my dad lent me for the test (out of his 250i6 powered buggy) and the mph were done by radar by the local cop i know him and he was happy to help my speedo was only 2 mph off. so thats not bad, truck appears to have only 87000mi unless its turned over already.
Old 11-10-2009, 10:53 PM   #7
leddzepp
Moderator
leddzepp's Avatar
Easy to figure out both posi, and gear ratio:
Jack the truck's back end up. Spin the tires. If they both spin in the same direction, you have posi. If they spin opposite of each other, you do not have posi.
Figuring out your gear ratio is easy. Attach one lug nut on one of the wheel studs for reference. I put it in the 12 o'clock position. You can mark a spot on the driveshaft for reference, or use the pinion yoke for reference if you do not have the driveshaft attached. If your driveshaft is attached, your trans will need to be in neutral. Turn your driveshaft and count the number of times it takes for that lug nut to reach the 12 o'clock position again. Mine took 3 3/4 turns, so I have a 3.73
If it takes 3 turns, you have a 3.07, 3 1/2 turns you have a 3.43 (unlikely), 4 turns, you have a 4.10, and so on.....
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-11-2009, 03:39 PM   #8
capev86
are you sure it is a dana 60 and not the corp/eaton HO52.....i think the dana came only on the trucks with big block or special ordered with the 3.54 axle ratio. the corp axle has a perfectly round pumpkin with 10 bolts on the diff cover and it came with a 4.10 or 4.57 (not 4.11 or 4.56) gear on a 3/4 ton truck.
capev86 is offline   Reply With Quote
Old 11-11-2009, 06:14 PM   #9
292farmer
292farmer's Avatar
heres some pics pretty sure a dana not an eaton, so not a posi but...tried that jack it up trick and first time 2 turns second and third to double check still only barely two turns?? spun wheel clockwise and counter then tried again still only two turns? definetly not right since it screams above 45mph
Old 11-11-2009, 09:55 PM   #10
leddzepp
Moderator
leddzepp's Avatar
Don't spin the wheel.....turn the driveshaft until the wheel makes one full revolution. Count how many times the driveshaft turned to get the wheel to rotate one full turn.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-11-2009, 10:23 PM   #11
Ricks' 72C10
Going Down?
Ricks' 72C10's Avatar
Ledzepp
I'm trying to figure out my gear ratio also
I marked the tire at 12:00 and turned the diff yoke, it took only 2.3 turns to come back to the top, less than 2 and a half. I tried it 3 times cause I couldn't believe it. What ratio do you think this one is?... A 2.30? It is factory stock '72 C10, it had straight 6 and 3 on the tree.
Just another day in Paradise
Rebuild thread
http://67-72chevytrucks.com/vboard/s...d.php?t=354512
Ricks' 72C10 is offline   Reply With Quote
Old 11-11-2009, 11:18 PM   #12
292farmer
292farmer's Avatar
thanks ledd zepp ill try that tomm. do u know how i can tell whether i have the ch/sm465 4spd or the np435 4spd? im told the np was more common in the gmc's the glovebox code says M20 4 speed trans. its not a huge deal with the trannismission im more curious then anything thanks!
Old 11-12-2009, 02:11 AM   #13
1968CHEVYC10
1968CHEVYC10's Avatar
Originally Posted by Ricks' 72C10 View Post
Ledzepp
if you have an open diff, and only wheel is spinning while your doing this, then you need to double it.
'68 C10 LWB 6.2NA/NP833 3.73's
1968CHEVYC10 is offline   Reply With Quote
Old 11-12-2009, 04:19 PM   #14
Ricks' 72C10
Going Down?
Yep...
Only the drivers side wheel was turning, so you mean maybe it is more like a
4.60 more or less?
Rebuild thread
Old 11-12-2009, 08:07 PM   #15
1968CHEVYC10
Yep...
4.60 more or less?
yea probably a 4.56
Old 11-13-2009, 01:07 PM   #16
Ricks' 72C10
Going Down?
yea probably a 4.56
If that is what it is, that will be good for what I am going to use it for... Strickly a street rod... no highway use.
Thanks man!
Good luck with your ride!
Rebuild thread
