Old 11-10-2009, 07:49 PM   #1
seafoam68
seafoam68's Avatar
Cool exhaust help
hey guys, getting ready to install exhaust and want some ideas/help. I will be running a 454 with 10.5:1 compression and a 3000 converter. I will use stock manifolds because of the expense of headers that fit right and I believe the stock manifolds will be good for low end torque. I want to run a 2-1/2" stainless dual setup with magna flow mufflers. Question is, H-pipe or X-pipe ? And any ideas on this set-up ? Also, I want the whole system in the frame rails, with nothing "hanging down". I have a 4 1/2" and 5" drop, and I cut two 4" holes in rear crossmember for pipes to go through.
seafoam68 is offline   Reply With Quote
Old 11-10-2009, 09:06 PM   #2
mcbassin
Still Learning
mcbassin's Avatar
Re: exhaust help
You might want to post this in the engine/drivetrain section. Those guys over there know everything about exhaust.......good luck!
mcbassin is offline   Reply With Quote
