Old 11-10-2009, 09:30 PM   #1
TurnNBurn
changing bolt pattern on wheels
Can I get a front rotor that will fit on my 78 1/2ton that will make it a 6 hole
, and is there a rear disc rotor the same pattern??, how about one that will make them 5 hole 4 3/4" pattern. The only reason I as is there is many more wheels avaliable for 6 hole , and 5 hole with 4 3/4 bolt patterns. Not many for the 5 on 5 I am assuming that is what come on my pickup
TurnNBurn is offline   Reply With Quote
Old 11-10-2009, 09:41 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: changing bolt pattern on wheels
The front is easy. Just call any 67-72 vendor and order a pair of 6 lug front rotors.
The rear, you can use 4x4 axles which are 6 lug.
Old 11-11-2009, 12:13 AM   #3
Stitch
Location: Where I come from, it's cornbread and chicken...
4x4 1/2 ton axles...if you swap rear ends, you want to stay 1/2 ton...3/4 and 1 tons are 8 lug
Stitch is offline   Reply With Quote
Old 11-11-2009, 11:08 PM   #4
spaseghost
certified tard
spaseghost's Avatar
hmm, i was also considering this for the wheel options. im guessing that the front rotor swap will be the same for 73-87? and how about putting in axle shafts, or should i just go 12 bolt for the rear?
85 swb bbc 5% tint
16.356 @ 84.81 8/07/09
4800 Ft., bad timing, carb tune, and traction, fugg it.
16.169 @ 84.29 8/28/09
good timing, no carb tune, some traction...
06 Equinox LT AWD, wife's and family ride
03 Mustang V6, CAI, Duals, Pullies, Programmer, Short Throw, wife's dream car?!
90 Eagle Talon, other project / space taker, GOT head!!
08 Silverado 2500 HD, the bad ass work truck
spaseghost is offline   Reply With Quote
Old 11-12-2009, 09:37 AM   #5
68 TT
Still plays with trucks
68 TT's Avatar
Go with the 88 up truck 10-bolt. They changed the axle spline count to make them stronger and the housing is a little wider to help even out the tire placement front & rear on the square body.
The larger 30-spline 10-bolt is just as strong as the truck 12-bolt and they still use it today so you can get low mileage posi carriers and gears out of wrecked new vehicles cheap.
The newer ones are even rear disc so you can mix & match parts to build a hybrid rear end that fits the older truck but has the disc brakes and newer posi.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577
69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been
69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc
68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E
79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars
68 TT is offline   Reply With Quote
