11-10-2009, 10:42 PM | #1 |
Tot Roddin'
Determining 2wd or 4wd (69-72)?
What features will assist in determing if a Blazer/Jimmy is in fact a 2wd vs. 4wd?
Frame differences VIN# Tub differences What do you need to look for?
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 11-10-2009 at 10:55 PM. |
11-10-2009, 11:52 PM | #2 | |
Re: Determining 2wd or 4wd (69-72)?
Sorry Nate, I couldn't resist! Ya gotta admit, you left yourself wide open for that though!
Wynne 70 CST short fleet Hugger orange & white, 350/350, ps, pb, air, tilt, tach/vac/speedwarning, original buckets, AM/FM, oak bed floor, shoulder belts, 3.5"/5.5" drop, 20" American Racing VN425s. Build thread 53 Chevy shortbed 69 Camaro Click here to subscribe Chevy GMC International Truck Club Louisiana Charter Member http://www.louisianaclassictruckclub.com |
11-11-2009, 12:00 AM | #3 |
Tot Roddin'
Ok there Wynne, that's the last time I ask for assistance from you. Why don't you just go build another beautiful truck...
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) Last edited by 72BlckButy; 11-11-2009 at 12:02 AM. |
11-11-2009, 05:54 AM | #4 |
2wd model key components...
frame differences - frame will be 104" wheelbase with rear coil springs with trailing arms - not leaf spring on the 4wd VIN - will begin with a C if it is a factory 2wd. If the first digit of the VIN of the truck is a K - it was originally a 4wd. front axle - 2wd - upper and lower arms and springs - not leaf spring straight axles like you find on a 4x4.. Tub differences - none. Except most of the 2wd Blazers I have found were rusted beyond belief... |
11-11-2009, 07:01 AM | #5 |
Aint 2wd blazers low hump and 4wd high humps
70 SWB STEPSIDE 70 BLAZER 09 challenger |
11-11-2009, 07:32 AM | #6 |
67-72 parts collector,…
Nate,... look at the rear frame rails. They should have the same shock crossmember as your truck. Coil spring area of the frame should look the same also.
11-12-2009, 04:16 PM | #7 |
I think the stock 2wd engine sits about 4" forward of the 4wd. This puts the transfer case shifter in a reasonable location. I think the frames have holes for both motor mount locations but a bad conversion will still have the engine in the stock location.
11-12-2009, 05:06 PM | #8 |
i believe there is a dimple in the frame on the drivers side.
11-17-2009, 09:57 AM | #9 |
Tot Roddin'
Thanks for the information guy's! I haven't been able to make it back out to look at the reason I made this thread.
As soon as I can get back out there and get some pics I will.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
