Old 11-10-2009, 10:42 PM   #1
bhammer
Rear Suspension help...
So I have a 72 longbed 2WD with the trailing arm and spring combination on the rear suspension. I was loading my harley for the first time into the back and notice that the suspension was so shakey while I was standing in the back. I wiggled from side to side so bad that I nearly dropped the bike. Once I had it loaded and secured it felt fine driving. Same thing happened unloading it, wiggled so bad form side to side it was precarious unloading it to say the least. Anyone know what I can do to make it a little more stable? Thanks....
bhammer is offline   Reply With Quote
Old 11-10-2009, 11:07 PM   #2
BAGNDRAGIT
Just Not Low Enough!
BAGNDRAGIT's Avatar
Re: Rear Suspension help...
i would check you track bar (panhard bar) bushings, and from there the trailing arm bushings.
also make sure everything is tight back there.
NEED ELECTRICAL HELP? ASK ME!
67-72 Full Wiring Diagrams
Lots Of Info, TAKE A LOOK
1967 Chevy C-10 Shortbox Bagged 327 4spd
Previous:
1971 Chevy C-10 Short Sep I6 Auto (Traded)
1973 Chevy C-20 *THE REDNECK BATTLE TRUCK*
2001 Chevy Silverado 2Dr 5.3L Shortbox. R.I.P.
1969 Volkswagen Bug
This is my first meeting, I have a horsepower problem.
BAGNDRAGIT is offline   Reply With Quote
Old 11-10-2009, 11:20 PM   #3
dan42
dan42's Avatar
Actually, these trucks normally are a little shakey when you get in the back of them, let alone with a 600 lb bike - especially the half tons.
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD
Click here to support the board
Philippians 4: 6-7
dan42 is offline   Reply With Quote
Old 11-11-2009, 02:59 PM   #4
69GMCLonghorn
69GMCLonghorn's Avatar
Simple thing, but make sure your shocks are good. If you start crawling around under there, have someone else shake it around. Somethign should jump out at you (not literally) if it's broken or loose.
69GMCLonghorn is offline   Reply With Quote
Old 11-11-2009, 03:30 PM   #5
capev86
new bushings (preferably poly) to tighten things up
modern shocks
rear sway bar will definitely help
3/4 ton rear coils if you plan to haul a lot.....stiffer makes for less sway
capev86 is offline   Reply With Quote
Old 11-12-2009, 05:12 AM   #6
unclewatts
70 Chevrolet=Obsession
unclewatts's Avatar
Betch'a it's the panhard bushings. They can be a pain to replace but it's worth it.
I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke!
IT'S NOT EASY BEING GREEN! -Kermit the frog
1970 Chevrolet C-10 Longbed Stepside :
350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes)
1996 Toyota Corolla (Parts runner)
unclewatts is offline   Reply With Quote
Old 11-12-2009, 07:43 AM   #7
292farmer
292farmer's Avatar
hey uncle watts is the m20 the trannsmission? (in your vehicle list) because my glovebox says m20 4spdmanual for the option list i looked at it and it looks like a sm465 or np435 is the m20 a code for one of those or does it stand for a whole different transmission? thanks my trucks a 1972 c20 292i6
292farmer is offline   Reply With Quote
Old 11-13-2009, 04:01 AM   #8
unclewatts
unclewatts's Avatar
That's an excellent question. Yes, it is on my SPID too and I'm not absolutely sure of what model transmission it refers to. It is a top loader with granny low and reverse is toward the passenger side and down. I believe it is a SM465 but I'm not positive. Maybe one of our more knowledgeable members could post an answer.
Old 11-13-2009, 05:17 AM   #9
bhammer
Thanks for the input guys. I am not sure of the problem. I know the previous owner has lowered the truck. I am guessing a 2/4 drop. I just thought the suspension should have been a little stiffer even with it being lowered. I haven't really crawled around to see if anything is loose. I am planning on tearing it down anyhow. Hopefully putting in some poly bushings will help. I am probably going to end up putting bags on the rear to stabilize it a little more and keep the ability to tow. This is my daily driver now so it has to be able to tow a bike or something of equal weight. Is installing a panhard bar a huge undertaking or is it pretty simple?
Thanks again.
Brian
Old 11-13-2009, 05:20 AM   #10
bhammer
Now that I have looked at it I don't think there is a stabilizer bar on it at all on the rear. When I unloaded the bike I had to put a scissor jack under the frame to keep it from wiggling so much.
Old 11-13-2009, 08:45 AM   #11
ebfabman
bhammer, nice truck andVERYnice springer. It's unlikely your truck has no track bar but as others have said the bushing may be worn out. Post a pic of the rear suspension and you will get all the help you need.
btw here is my springy
ebfabman is offline   Reply With Quote
