Old 11-10-2009, 10:56 PM   #1
thelonerife
thelonerife's Avatar
Thumbs up WTB 5 lug 15x 8 stock rims hubcap style(not ralleys)
I was wondering if anyone had some special made 15x8 stock rims or if they even exist and you weren't going to use them. Of corse they must be straight and rust free for the most part. And good lug holes. not wallered out. I want to run the 1/2 ton dog dish style caps. I would also be interested in 6'' ones for the front. post pics if you have any. Closer to me the better too.thanks Chuck.
5x5 pattern only
thelonerife is offline   Reply With Quote
Old 11-11-2009, 01:15 AM   #2
thelonerife
Re: WTB 5 lug 15x 8 stock rims hubcap style(not ralleys)
ttt
Old 11-11-2009, 07:44 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
These things are impossible to find. I've been looking for a pair for my junk forever. I'm just going to build a pair for my truck using hubcap centers from a normal 6 inch wide hubcap wheel and 8 inch rally wheel hoop. I've done the measuring and it will work. Tech post coming soon when I do it.
Old 11-11-2009, 08:29 PM   #4
thelonerife
I'll look for it.thanks.tf
Old 11-11-2009, 09:13 PM   #5
woodridge
woodridge's Avatar
It should be a rather easy do, with the correct equipment. Why don't you come over and we'll build you a set.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 11-11-2009, 09:15 PM   #6
thelonerife
I will have to locate some rims of both style first. I'm assuming that the hoops are the same
Old 11-11-2009, 09:21 PM   #7
roughedup72
roughedup72's Avatar
I've got all four of the 6" wheels. They came off my 72, Thought I would keep them just in case I needed them but would rather see them go to some one who needs them. PM me if your'e interested.. They're in great shape also.
1972 chevy cheyenne 10,nothing special at the moment,Its a work in progress, Working on the engine, paint and body,engine, paint and body,now its the suspenion, ahh hell I'm about tired of working on it. Maybe it will be a rat rod.
roughedup72 is offline   Reply With Quote
Old 11-11-2009, 09:39 PM   #8
thelonerife
roughed up. I'll let you know if I can't get some thanks a lot!!
Old 11-12-2009, 07:26 AM   #9
You can prolly use 8" white spokes for the rim,if you don`t find cheapo rallyes.Tim Christian has an orange powder coated set that with painted 6768 caps.The wheel color matches the color in the caps.They are hard to find,but out there.I found mine a few years ago.just trying to get the truck up to where these go on:
I hope you guys come up with some.You know it would be easier to grab a set of 20-somethin`inch hoopty hoops.
I`m always looking for these.I`ll let you know if I find any.
Old 11-12-2009, 12:34 PM   #10
woodridge
woodridge's Avatar
Chuck, I have the extra ralleys if you can find them.
Old 11-12-2009, 09:24 PM   #11
thelonerife
I may have found the stockers. I need 2- 8'' ralleys now.I'm only wanting 2 for the rear
Old 11-12-2009, 11:22 PM   #12
woodridge
woodridge's Avatar
Got you covered.
Old 11-14-2009, 10:32 PM   #13
thelonerife
I have 5 stockers now. I have to get the tires off of them. then get the middles out of two of them.
Old 11-23-2009, 06:06 PM   #14
thelonerife
I got started on these. I used a cutting wheel on my grinder. I first cut two cuts across the wheels, then cut the welds being careful not to get into the wheel center.just cutting the welds. A couple smacks and they are out. I have to find a couple 8''ers then do the same. I'll try to find some around here Woody. Thanks. some pics.
Old 11-23-2009, 06:37 PM   #15
Boog
laying low
Boog's Avatar
You make it look easy.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-23-2009, 07:30 PM   #16
hotrod 80
mini truck racer
hotrod 80's Avatar
Keep us posted on the outcome .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 11-23-2009, 10:39 PM   #17
northern 85
northern 85's Avatar
Very interesting!
northern 85 is offline   Reply With Quote
Old 11-24-2009, 08:28 AM   #18
This is gettin`to be a FAQ thread.This is great! I may just be making me some 10 inchers.
Old 11-24-2009, 01:09 PM   #19
thelonerife
them I'll take your 8's lol
Old 11-24-2009, 03:41 PM   #20
Maybe runnin`this wheel job on here will bring the 8-inchers out of the woodwork.I only have one set in red.Think of all the colors.I need more!
Old 11-24-2009, 05:13 PM   #21
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
I think I have one out in our barn that's 8 inch and 5 hole steel and not Rally. Not that it helps at all. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-24-2009, 07:52 PM   #22
thelonerife
lmk if you do. maybe you'll have two??
Old 11-24-2009, 09:55 PM   #23
71blksuper4x4
SWB 4x4 Collector
cleaning the barn out tomorrow, will let you know what I find. I think I only have one that I know of. Trevor
TREVOR
Old 11-24-2009, 11:14 PM   #24
thelonerife
thanks Trevor
Old 11-25-2009, 07:45 AM   #25
If it turns out you have 5 or more I`d like the extra ones.
i went to a local show that has 4 or 5 people selling parts.There I saw a nice never painted 5-lug 8" rims.I was holding back the adrenaline until I could ask if those are truck pattern.He said they were.How much?$100.My head started reelin`....."I`m broke,but I have to buy these somehow.Jason`s going to show up.Maybe I could leave this guy $20 and Jason will have the other $80.If he does,hopefully he`ll give me time to pay him back.i need these wheels bad!"....so,i give the guy a $20 and tell him i`kll be back before I leave...SOLD!! before Jason gets there I`m walking back past the guy and he comes running up with my twenty.I`m confused why he`d be handing my money back as he explains that he measured them to be sure and they were Ford pattern...."WUH??Could you measure them again?'...bummer
