![]() Join Date: Aug 2008
72 cab bare swb frame 72 doors swb & lwb fleet beds step fenders no spare cut out
I have accumulated way too much stuff in the past few years. Here is a list of thing off the top of my head. Pics will be posted as time allows. No shipping unless otherwise noted.
1973 454 High perf block that needs .060 overbore Casting #'s are 3999289. It is a 2 bolt block $150 SOLD 1972 Chevy truck factory AC bare cab SOLD 1972 rust free doors, minor dents $200 pair 1972 Chevy swb bare frame $200 1968-1972 swb fleetside bed - rough but I have another set of bed sides $500/ all 1968-72 fleetside LWB bed, almost perfect steel floor and driver side, one dent on pass side $300 SOLD 1968-72 Stepside fenders, no spare tire cut out on driver side. NEARLY PERFECT CONDITION, no filler , original paint-1 pair left SOLD 1968-72 3/4 ton full floater rear axle not sure of ratio, set up for leaf springs $150 1982 Suburban SILVERADO roller- good body, no engine or trans clear title $400 http://67-72chevytrucks.com/vboard/s...46#post3512746 1994 Chevy truck regular cab w doors, clutch pedals and dash, no seat, inst cluster or door panels, broken tilt wheel $300 1994 Chevy LWB fleetside bed tail lights and tailgate no rust minor dents on pass side $300 1994 Chevy 3/4 ton 2wd lwb reg cab rolling chassis $200 Impco propane regulator and adapter for Chevy TBI no tank SOLD 1969 350 engine, runs casting # 3932388 block & casting # 333882 1974-1980 76cc heads, aluminum intake, cam specs unknown, (?) has been rebuilt runs good $400 SOLD 1999(?) EZ GO Electric golf cart, batteries less than 2 yrs old, need repair, not working SOLD Rota Bin Industrial bolt 5 row storage bin needs bearings and paint $100 Last edited by WIDESIDE72; 01-10-2010 at 01:01 PM. |
![]() Join Date: Sep 2009
Re: 72 cab bare swb frame 72 doors swb & lwb fleet beds step fenders no spare cut out
Interested in 72 doors.Looking for orignal paint no bondo.
Thanks Paul |
![]() Join Date: Feb 2003
is the cab rust free? if so im in....
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
mini truck racer
Intrested in pics of the cab and doors .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
Interested in a passenger SWB bedside in you want to split. Please send pics.
Thanks, Stephen |
Pics of cab with the DS door mounted. They are the ones for sale separately. The doors are yellow and appear to have original paint. They both need some dent repair to the lowers, but no rust through.
Front clip, bed and chassis is gone, sorry. It was the only pic I had of the cab that wasn't up close. Obviously, this isn't a "bolt it on and go" cab.
Evaporator box on firewall is missing. It needs patches on floor boards both sides. No rust to the cab supports that I can see. Last edited by WIDESIDE72; 11-11-2009 at 09:45 AM. |
Pics of swb fleet bed. Will take pics of bedsides I planned to use and post them ASAP.
I almost forgot, I also have a van tilt column that was in pretty good shape as well. Will take pics and post ASAP. sold
DS of swb bed not too bad, ps is toast. Both sides have the panel behind the rear tires folded under. Floor is pretty nice, one hole for a trailer ball (?)
#13 |
This is the only pic of PS door I currently have. Will take more and post ASAP. Pic of DS door is at first of thread as pics of whole truck before I parted it out.
#14 |
It has some bondo on the bottom portion, but still has original paint on top portion
#15 |
When you have so much "JUNK", it is hard to keep track. I forgot that I had these 71 doors off a truck I parted. They need some work, but I think they were salvageable. Appears to be original paint. They have had some brazing repair to the hinge areas, looks solid to me. There are a few rust holes as well. Also, at least one, possibly both skins are cracked where they didn't have support, in the area were GM added the screw inside on 72 doors. $100 for the pair
#16 |
I think you get the idea that the 71 doors need work. I hit the rusty spots with a wire wheel to stop the rust and sprayed some oil on them. The 72 doors are much better.
#17 |
Pics of bad spots
#18 |
more pics. full disclosure HAHA
#19 |
71 door pics
#20 |
72 door pics glass and mechanism included door panels and hinges not included.
#21 |
Sorry pics are so dark. I was using the wife's new camera and havent learned how to do so properly yet. The filler on the pass door looks entirely unnecessary to me. I think it was done by someone with absolutely no experience trying to fix a dent.
#22 |
68-72 swb fleet bed sides. These came from two different trucks.The driver side has had the stake pockets welded up. The pass side hasnt. The pass side will need the strip that bolts the bed side to the floor replaced. The driver side is OK. Both of them have a hole where the metal rusted away behind the rear tire, right at the corner. The pass side has a couple of dents. These will need work, but IMO are better metal than repros. which are almost always thinner and softer metal.
#23 |
pics
#24 |
DS also has a torn (?) spot at bottom below tail light. IMO, this could be welded back together fairly easily.
#25 |
no rust through on yellow 72 doors that I can see. Will post better pics as time allows.
