Old 11-11-2009, 01:13 PM   #1
Chevys4ME
Droping 67 w/85 front
I have found a 85 chevy front end to put under my 67 so i can have disk power brakes and power steering. So now i am wondering to drop it do i just need to buy 85 chevy drop spindles or is there a better way? I am only dropping it 2.5 inches so will just drop spindles work?
Chevys4ME is offline   Reply With Quote
Old 11-11-2009, 04:21 PM   #2
71tahoe
71tahoe's Avatar
Re: Droping 67 w/85 front
Make sure your doner front end has 1.25" thick spindles. For the most part, all I've seen in drop spindles were for the heavier duty rotors.
71tahoe is offline   Reply With Quote
Old 11-11-2009, 04:30 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You can get drop spindles for either the thin or thick rotors. They will give you either 2.5 or 3 inch drop depending on which brand you choose.
Another option is either a 2 or 3 inch drop spring instead of the spindle.
Old 11-12-2009, 01:11 PM   #4
Chevys4ME
Which would give you a better ride drop spindles or drop coils?
71tahoe do you mean rotors or spindle 1.25 thickness?
Old 11-12-2009, 01:22 PM   #5
Tx Firefighter
Drop spindles will give better ride. They will not affect the ride at all. Springs will.
71tahoe means measure the thickness of your brake rotors. Either 1 inch or 1.25 inch. Light or heavy duty brakes. You will need to know which you have to order the right spindles.
Old 11-12-2009, 01:55 PM   #6
71tahoe
71tahoe's Avatar
Yes, rotor thickness. I swear I fixed that before I hit submit...
