Polyurethane Mounts
Hi, I bought a complete cab mount kit from Energy Suspension. I've heard that it is not recommeded to use the poly mounts for the rad core support and that you should use the original rubber mounts. Anyone know anything about this? Thanks.
Re: Polyurethane Mounts
i heard the same thing. how much was you kit ?
Bought it from Classic Industries. List was $65, but I had it shipped to Canada, so probably paid around $80 for it all in. Part # 34108g
When I asked, the consensus was that the stuff that needs to give/move should be rubber. The Cab, engine and radiator supports should all be rubber, poly for the suspension parts.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 Last edited by dfwright; 11-11-2009 at 02:32 PM. |
I agree, poly under the cab will likely give you a stiffer ride. The point of the rubber mounts is to isolate you from the road vibrations. Poly will transmist more of that vibration into your seat. Only advantage I see is that poly will last longer. I use poly only in my suspension where you want to reduce deflection and maintain proper geometry at all times.
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
While we are on the subject of cab mounts, can you replace the cab mounts with the cab still on the truck? I do not want to dismantle my truck to change cab mounts.
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
And the front cab bolts might need a tack weld ground off in order to remove them. You won't be able to easily jack it up enough to install those bushings with the bolts in place.
rubber all the way around is the way to go with daily driven trucks
Moderator
![]() Join Date: May 2007
I have poly mounts on my cab. Not one problem.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I have the LMC original style cab mounts, they seem pretty nice. I have the energy leaf spring bushings and they are stiffer than stock, that's for sure... of course I haven't driven it yet...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
I have the urethane under my support. I've never had a problem.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
#13 |
Im glad i read this, I had a new set of poly mounts but after reading this i ordered rubber ones and put the poly ones on ebay.
#14 |
i bought a kit of rubber mounts for the whole truck it wasnt a bad price.. im 185 pounds and i installed my cab mounts by myself "already gone" if u can crawl up on your back and use your knees to help lift the cab along with one arm it was easy for my to slide in the mounts and the plates.. the cab aint that heavy
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
