Old 11-11-2009, 03:24 PM   #1
big10ratrod77
big10ratrod77's Avatar
454 build?
hey yall
within the next year were going to build the 454 in dads dulley,
and i was wondering what would be some good parts to add to the engine couse we want to pick up some power but keep it streetable (as streetable as a 454 can be) so i know how to port and polish so thats definatly gonna happen. but the only other engine ive built is a plymouth 225 slant six so im lost over here in 454 land trying to figure out what a good towing cam would be(still have no clue) and what kind of intake maniflold. i want to keep the q-jet couse i realy like the carb.
so heres a few questions i got
how much compression can i run with the cast iron heads.
do roller rockers help eny with power and how?
what is the stock rocker ratio on our 454?
what would be considered a towing cam? (its had a cam swap but this cam dont have alot of bottem end torque)
and what brand of headers and what type of headers would work best with a towing application(i dont like warped leaky headers)?
so eny suggestions would be very apreciated
and i want the engines apperence to look mostly stock like a sleeper kinda if you know what i mean
77 chevy BIG 10 350/sm465/12bolt w 3.73 bout 240 horse power NO power steerin
79 chevy 1/2 ton 250/three on the tree/3.08s soon to get built 250/floor shift conversion/3.08s
81 mercedes 300d 25 MPG
77 chevy BIG DOOLEY 454/sm-465/14 bolt 4.10s "fully loaded"
73 plymouth duster 225 slant six/230 3 speed/8 1/4 trying to acheve 300 horse six http://www.cardomain.com/ride/3135091
'77 chevy trucks. built to stay tough.
life is short build a hot rod
big10ratrod77 is offline   Reply With Quote
Old 11-11-2009, 03:30 PM   #2
grinch4om
dang its hot
grinch4om's Avatar
Re: 454 build?
do a stock rebuild, little more cam (210@.050 dur.500 lift)...weiand intake for the peanut port heads, good Q-jet or spreadbore holley....headers, good dual exhast minimum of 2 1/2 inch pipe, free flow mufflers of your choice. HEI distibutor or MSD ...this makes for a solid fun reliable truck motor. there tons of other ways to make power but this is an inexpensive solid method
grinch4om is offline   Reply With Quote
Old 11-11-2009, 05:12 PM   #3
big10ratrod77
Re: 454 build?
so whats up with the peanut port ive herd of them but i have no clue what they are?
Old 11-11-2009, 10:04 PM   #4
budgetstperformance
budgetstperformance's Avatar
Re: 454 build?
there are three different style intake ports
1. square port you will find in hot rods like 454 chevelle
2. oval port dont know much about these
3. peanut is standard for 454 truck motor since 1975. it restrictive which build torque for towing
budgetstperformance is offline   Reply With Quote
Old 11-12-2009, 12:10 AM   #5
1985LT1_C10
1985LT1_C10's Avatar
Re: 454 build?
if your gonna port the stock heads bump the valve size up to 2.19/1.88 i/e. this will help tremendously. the best head numbers are 041 and 781 these heads when ported and larger valves make huge power for the size of the truck and im assuming your keeping the gearing fairly high stay with a short duration somewhere below 220 @0.050 lift generally should be around .500 the shorter duration will keep the power lower in the lower rpm range. as for the intake i have had luck with the edelbrock performer. go with 1.7 rocker arms. roller tip or even stock stamped are fine...dont have to go overboard if your not building a screamer and any header with 1 7/8 primary tubes are what id look for and im glad to see that your gonna use a q-jet!! hope this helps
Ross K
1985 Silverado LT1
1970 Chevelle SS396
1985LT1_C10 is offline   Reply With Quote
Old 11-12-2009, 08:30 AM   #6
big10ratrod77
Re: 454 build?
do these engines have dished pistons from the factory? i know the 350s did couse i want to go a little higher on the compression side of things
Old 11-12-2009, 08:39 AM   #7
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: 454 build?
I believe they do, subscribing to the thread, I plan on building a mild big block in the near future for my 78 K30.
GCncsuHD is offline   Reply With Quote
Old 11-12-2009, 11:03 AM   #8
SSC's76
No No
SSC's76's Avatar
Re: 454 build?
Well this is what I suggest seeing how towing is what were looking to do with the truck. As long as you stick with a cam in the 220@.50 durration with the 454 it will work very well. That may seem big but were looking at a 454 not a 350 the 100 extra cubes needs a little more lift then your run of the mill 350. Stick to a small free flowing intake the the edelbrock performer intake. This is a great intake on a BBC much better flow then a stock intake and about 20lbs less weight. Headers are of course upto you. The flange area has a better mounting surface on the BBC so headers on a BBC arent as leaky as SBC applications so wall thickness is more important then flange in this choice. Heads as long as they have a 2.19 intake and 1.88exh vale in them like mentioned above will work great and have plenty of flow just gasket match them. Going all out on a tow rig isnt nessasary. Id go with stock pistons most are either small dish mostly ive seen flat top with small valve releif area cut into them. A lower compression engine is better suited for towing since its not going to be as picky on the quaility of fuel. Trust me there nothing worse then having a trailer behind you pulling a grade and having to back out of the gas becasue the engine starts to ping. Stock compression will be fine shoot for a max of 9:1. Other then that you may consider upgrading the 30 year old HEI to a new Accel unit to give a properly working distributor is great to have but of course may be nothing wrong with the current one.
1976 Custom Deluxe SWB Med FMB.3/4 Drop.
Gen VI 454, Muncie HD 3 speed With Modified OE Hurst Shifter, 3.73 12 bolt, GMPP HO roller cam, Hooker headers, Performer intake with modified Q-jet, Accel distributor. Best 1/4 12.3 @108. Funnest run 19.84 @88 full 1/4 mile burn out.
1997 K1500 ext cab 5.7 stock except muffler
SSC's76 is offline   Reply With Quote
Old 11-12-2009, 01:01 PM   #9
streetstar
streetstar's Avatar
Re: 454 build?
Thats some solid advice SSC ---- no sense in trying to turn a mule into a race horse, but a couple of smart mods may augment its towing ability.
Are you retired too?
Nonsense! I'm in my prime
streetstar is offline   Reply With Quote
Old 11-12-2009, 08:14 PM   #10
LiveAnimals
LiveAnimals's Avatar
Re: 454 build?
My 454 is basically stock, it has a mild edelbrock cam with roller rockers, edelbrock mani and holley carb, LT headers to a stainless X-pipe to flowmasters. Its a very torquey p/u, but cruises just fine. Oh it also has 3.73s
Kameron
YESTERDAY IS HISTORY - TOMORROW IS A MYSTERY
I'm a Middle ClASS HOLE
07.5 Dodge 3500 CTD -- Daily
73 C10 Factory BB SWB 2WD
LiveAnimals is offline   Reply With Quote
Old 11-12-2009, 08:41 PM   #11
JCampbell
Re: 454 build?
Subscribed...
JCampbell is offline   Reply With Quote
Old 02-02-2010, 07:07 PM   #12
Re: 454 build?
I'm getting ready to put together a 1976 GMC 1 ton dually I bought from a member here. Very excited I just ordered the engine build from Mark in Colorado, a 454 putting out 455HP and 550 Ft Lbs of torque with an 8.5 to 1 comp. Having a turbo 400 built also.
Old 02-02-2010, 07:58 PM   #13
bigarmzz
bigarmzz's Avatar
Re: 454 build?
its been awhile, but i think they were 049's, not 041's werent they?
1987 350 TBI lowered 5/7
bigarmzz is offline   Reply With Quote
Old 02-02-2010, 08:27 PM   #14
b454rat
Re: 454 build?
Yeah 049 and 781 heads are about the best large oval port heads without spending crazy money. 9:1, mild cam, intake, headers, good exhaust and you will plenty of power.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 02-02-2010, 09:13 PM   #15
80SPORT
80SPORT's Avatar
Re: 454 build?
By far your best value is to purchase the 502 HT crate motor from GM part #88890534;Brand new,warranteed for 2 years;no oil leaks;hydraulic roller cam;just add a dual plane intake and edelbrock carb.You cant beat cubic inches in a tow vehicle ....I would not even put headers on ...they leak and pop gaskets after a while ...just put a good dual exhaust on.
Nice truck ....77's are a one year truck with the yellow in the trim
80SPORT is offline   Reply With Quote
Old 02-02-2010, 09:43 PM   #16
dan76
Re: 454 build?
While you're at it, consider going for a NV 4500 trans for the OD.
dan76 is offline   Reply With Quote
Old 02-03-2010, 01:21 AM   #17
po_bird
po_bird's Avatar
Re: 454 build?
you are right. it is 049
72 SIERRA LB
74 C10 SB
85 C10 SB
75 EL CAMINO SS
po_bird is offline   Reply With Quote
