11-11-2009, 05:42 PM | #1 |
Mean Buzzin' Half Dozen
How Much Oil in a 250 Inline 6?
Did some google searching and couldn't seem to find any answers. I don't know where the Chilton's manual we have is as it got lost in the recent move. So if anyone could tell me real quick how much oil to put into the Inline 6 I would really appreciate it.
"War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself."
MY TRUCK (Now for sale) 1967 C10 SWB Dylan |
11-11-2009, 05:45 PM | #2 |
Watch out for your cornhole !
Re: How Much Oil in a 250 Inline 6?
6 quarts if you run a full size filter. 5.5 if you run a shorty.
11-11-2009, 05:45 PM | #3 |
Resident Curmudgeon
5 quarts with stock oil pan on a 250 or 292
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
11-11-2009, 05:46 PM | #4 |
Thanks loads!
11-11-2009, 05:49 PM | #5 |
Well, you got two different answers.
11-11-2009, 06:01 PM | #6 |
5 qts with filter used to fill mine to the little dots on the stick.
11-11-2009, 06:21 PM | #7 |
Another question if you don't mind, my truck is idling really low, and it will idle at that low RPM for a little while and eventually die. It never did this until recently. My guess is the idle screw has backed out some. I check the fuel filter and lines and fuel is getting to the engine fine with no lack of fuel. Where is the idler screw located on a 1 bbl Rochester Monojet? I can't seem to find it. Unless it's on the dark side closer to the firewall. I guess I'll grab a flashlight...
11-11-2009, 07:25 PM | #8 |
Active Member
As per my original owners manual on my 69 and 68 and 65-72 Chiltons.
Five quarts with a filter change. Idle adjust screw is on the firewall side of the carb. You access it from the passenger's side. |
11-11-2009, 07:30 PM | #9 |
Active Member
One more thing, these little carbs are notorious for leaking gaskets. Make sure the bottom is tight and in mine I had a loose base. I found it by actually removing it and accessing the screws from the bottom.
Good pics on this site. You can see the idle adj screw next to the bellcrank #44. http://www.carbkitsource.com/tech/Ro...ojet/1ME-1.pdf |
11-11-2009, 07:31 PM | #10 |
Shrugging my shoulders. I changed the oil in my 250 earlier this week. First time, I used a long filter and it took 6 to get it to the full mark. I ran the engine awhile and changed it again. This time I used a short filter and it took 5.5 quarts.
Maybe our oil pans are deeper in Texas. Everything else is bigger.
11-11-2009, 08:50 PM | #11 |
Active Member
Re: 6 quarts. The books say that with long or high capacity filter add 2 quarts. Could be the the dipstick is a little off. Mine is pretty much on the money with the recommended 5 quarts-maybe a smidgen low.
The 292, 305 (v6), 351 (v6) use 5 without the filter with 1 quart more for filter change. |
11-11-2009, 08:53 PM | #12 |
Do you have a 250 or 292 oil pan?
11-12-2009, 10:27 AM | #13 |
Resident Curmudgeon
My 292 takes 5 qts with filter IIRC. I guess the answer is buy 6, use 5, run, check, add as needed.
04-11-2019, 02:39 PM | #14 |
(Resized image)
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! Last edited by LockDoc; 04-12-2019 at 12:16 PM. Reason: Image too big |
04-11-2019, 02:59 PM | #15 |
I have a radical idea!
Holy Old Post, Batman! 😂
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
04-11-2019, 03:11 PM | #16 |
Who Changed This?
What year big block? Mine only takes 5 with a filter change. Maybe the dipstick is wrong, somehow?
04-11-2019, 03:44 PM | #17 |
Every big block I’ve ever had took 6 qts. I’ve had early 396’s - 90’s 454’s and pretty much everything in between.
04-12-2019, 10:44 AM | #18 |
Who Changed This?
That's something I'll have to check into. I'll start with the length of the dipstick tube after I change the oil and verify the amount required. It's due for a change, anyway.
