11-11-2009, 06:32 PM | #1 |
Speedway control arms
I was looking thru a speedway book and am thinking of using their upper tubular control arms, but not sure which ones I need. I have a 70 camaro clip on a 56 . My choices are a offset style or one thats centered and would my clip be metric? They also come in different lenghts from 8" to 9 1/2". I assume this refers to length from mount to center of ball joint? I am running bags so would a longer than stock arm be of any advantage?
11-11-2009, 11:19 PM | #2 |
Re: Speedway control arms
Becarefull if it's a racing application. Most don't have bearings and any bit of dirt will wear them out. As an alternative look at Joesracing.com and look at his sealed bearing control arms.
11-12-2009, 01:44 AM | #3 |
Metric chassis is G bodies from '79 to '88. The thing about circle track parts is you might have to do some fabricating to get'em to work right. For something as belly button as a Camaro clip I would just order some bolt-ons.
