Old 11-11-2009, 07:12 PM   #1
northerngmc
northerngmc's Avatar
Brake line seized to brake hose HELP
So I am in the process of trying to change the front brake hoses on a 69 GMC. The left side went well.
On the right hand front I can not get the fitting to come loose where the flared fitting goes from the hard line to rubber hose.
I first sprayed everything with penetrating oil and cleaned off all the dirt. Next I tried turning the flared nut with a wrench ( regular not flared wrench) and it has stripped. I have now tried a bit with a vise grip which is simply taking the nut apart.
Any suggestions?
Blaine
59 GMC 9314 a.k.a. Whoopee
68 C20 50th Anniversary a.k.a. The Rat
http://www.flickr.com/photos/northerngmc/
http://www.members.tripod.com/P-wee/index_032.htm
1.61803 is one H of a lot better than 3.14159, no really it is!
northerngmc is offline   Reply With Quote
Old 11-11-2009, 07:32 PM   #2
mbgmike
Re: Brake line seized to brake hose HELP
Any suggestions?
sometimes you just have to take a small die grinder and cut them off and replace.
mbgmike is offline   Reply With Quote
Old 11-11-2009, 07:38 PM   #3
cdowns
cdowns's Avatar
change to new hard lines they're cheap enough to replace
Old 11-11-2009, 07:43 PM   #4
independentcustoms
Just this past week I needed to change a wheel cylinder on my 71 C20, and had a similar situation. I decided it just wasn't worth going through this hassle next time something goes bad in the brakes, and redid the whole system. I did the hoses, steel lines, shoes, wheel cyls, etc.
independentcustoms is offline   Reply With Quote
Old 11-11-2009, 07:51 PM   #5
northerngmc
Well parts are at least a week away so I am looking for a today or this week solution.
Can the line be cut and a new end flared on? Or if it is then too short, can another piece of hard line be add in with a junction block or does the whole line need to be replace?
Blaine
Old 11-11-2009, 07:54 PM   #6
northerngmc
So what are factory hard lines made of?
Blaine
Old 11-11-2009, 07:57 PM   #7
Blazer1970
Blazer1970's Avatar
You can splice in another piece of hard line with a flared union, or just cut the hard line shorter and re-flare if the hose is long enough. Don't forget to put the flare nut on the line before you flare it.
Blazer1970 is offline   Reply With Quote
Old 11-11-2009, 07:57 PM   #8
67ss&99ss
Andy
Yes, you can add a new piece with a union. That would be the easiest. If you have a bender, go to the store, get a new line cut and bend it however you need an join it together with the union. I had to do this on the back of my C/10. Alot of times, on those stubborn lines, I have tried tightening them some then loosening some, back and forth, back and forth, and they've eventually broke free.
1967 Camaro SS 406|522hp/514ft lbs|M20 Muncie|3.73s|Posi
1969 CST/10 383|Aisin AR5 5 speed
1972 K5 350|Turbo 350 4x4
2005 Duramax 2500HD 4x4
67ss&99ss is offline   Reply With Quote
Old 11-11-2009, 08:03 PM   #9
northerngmc
So what type of flare is it? Single, double?
Blaine
Old 11-11-2009, 08:05 PM   #10
mclairmo
Any parts place should have lengths of brake line with fittings already on each end. I usually go to Kragen or Napa. You can also purchase a double flaring kit and then cut those new lines down to the exact length or add different size fittings if need be. It should not be a one week proposition. Other than, the only other quick solution is to leave it as is.
mclairmo is offline   Reply With Quote
Old 11-11-2009, 08:06 PM   #11
mclairmo
steel
Old 11-11-2009, 08:07 PM   #12
mclairmo
double
Old 11-11-2009, 08:16 PM   #13
northerngmc
I agree it should not be a problem but I live in a small, 2500 people, isolated town, with the nearest town being 270 kms away and it is less than 4000 people.
Blaine
Old 11-11-2009, 08:21 PM   #14
northerngmc
The pipe is cut off right above the fitting and the pipe is cleaned up.
Now to find a new flare nut and tool at 5 PM on a holiday! I think we will have to wait until morning.
I am typing on the hood!
Blaine
Old 11-11-2009, 08:56 PM   #15
hayhauler71
hayhauler71's Avatar
Cap off the line so your master cylinder does not run dry. This will save you some time during your bleeding procedure.
hayhauler71 is offline   Reply With Quote
Old 11-11-2009, 09:00 PM   #16
lilred67
lilred67's Avatar
i have used a propane torch to heat up the hard line/nut and free it up enough to get it to unscrew.
i'm sure some safety guru will chime in on that...lol but it works!!! rusty
lilred67 is offline   Reply With Quote
Old 11-11-2009, 09:51 PM   #17
leddzepp
Moderator
leddzepp's Avatar
Consider purchasing line wrenches in the future so that this does not happen again.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-11-2009, 11:05 PM   #18
northerngmc
Yeah we tried that. One safety issue I found online was to make sure the hose is disconnected or the bleeder screw open to allow the extra pressure of hot brake fluid somewhere to go.
Blaine
Old 11-11-2009, 11:07 PM   #19
northerngmc
I understand the idea of flare nut wrenches but I don't think they would have helped here with the amount of corrision on the line with the nut.
But yes, my father always told me to be extra careful when turning flare nuts as they are soft, and we used his flare nut wrenches.
Blaine
Old 11-12-2009, 12:04 AM   #20
northerngmc
I had thought about doing this and then didn't but after your post went back thinking maybe I still had time. 2 hours had past and there was no sign of any brake fluid dripping.
Hummmmmm, is the line that small that air won't get back up to let the fluid run?
Blaine
Old 11-12-2009, 01:13 AM   #21
Smallz72project
Smallz72project's Avatar
As a certified brake technician I run into this sort of problem all the time....about 4 out of 10 times I end up having to replace the line. Rule one....dont ever use any type of penetrating oil or liquid on anything in your brake system shy of caliper bolts and the sort. If any amount of that gets into your system it will contaminate it, which A) is not fun to fix and B) not cheap. If you or anyone else ever encounters this problem, best method to do is use heat and not a propane torch cause it just wont get hot enough. You need to use an actual torch and you heat up the nut and just work it a bit at a time and repeat if needed. If you end up burning throw the line or it just wont come unstuck...it is okay to cut the line and reflare it. If it doesnt seem to be quite long enough initially, you can pull some more brake line down carefully as not to actually kink the line. If you dont feel comfortable with that, I would recommend simply buying a new line from the master cylinder to the hose. You want as little junctions as possible, less junctions= less chance of leaks and or blockages.
- 1967 Chevy C10 shortbox
- 1984 Chevy K10 "Mater"- SWB 305 manual, retired sheriffs truck, Current Frame Off Project
- 1986 Chevy K10 LWB 350/350 Daily Driver/project
Smallz72project is offline   Reply With Quote
Old 11-12-2009, 01:37 PM   #22
mbgmike
steel
aka
bundy tubing
Old 11-13-2009, 01:54 AM   #23
OldCreek
OldCreek's Avatar
Does that include using thread sealer? (Tape or grease)
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-13-2009, 02:02 AM   #24
joedoozer
is Certifiable
joedoozer's Avatar
You should never use any type of teflon tape or sealant on flared fittings. Thread tape and sealants are for pipe threads, fittings that seal using the threads. Brake lines seal at the flare. Sealants and tape do nothing with flare fittings. If you have a leak at a flare fitting, you need to remake the flare, not use sealants.
As for freeing up rusty fittings and bleeders. Use a oxy/acet torch and get it hot. Wrap the rubber hose in a wet rag to keep it from getting to hot. Once the fitting or bleeder is hot, dowse it in cold water. The temperature shock should break it loose. But like others said, cutting the line and flaring it makes the most sense.
1972 Chevy C10 LWB 350 Auto
Blue with a white roof.
joedoozer is offline   Reply With Quote
Old 11-13-2009, 11:37 AM   #25
northerngmc
Well the line has been cut, flared, leaked, reflared and now all is fine.
Just need to rebend the line after flaring and hope it is long enough.
Thanks to everyone for your great input.
Blaine
