Old 11-11-2009, 08:01 PM   #1
indianpride77
indianpride77's Avatar
Heater Question
ok so with winter coming along and having a really cold morning this morning. i'm really starting to get into my heater issues. now i'm just curious if all older blazers have the same issue of the temp being warm from the heater but not hot, or is it just mine? granted it does clear the windshield after a few minutes but thats about it. i really don't notice it getting warmer at all inside. any help would be great
indianpride77 is offline   Reply With Quote
Old 11-11-2009, 09:06 PM   #2
swyfor5
swyfor5's Avatar
Re: Heater Question
Probably like my 70, needs a new heater core!
swyfor5 is offline   Reply With Quote
Old 11-12-2009, 08:43 AM   #3
vtblazer
vtblazer's Avatar
Re: Heater Question
Heaters in these old trucks work great, when they're in 'proper' working order.
Keep in mind that 37 plus years is going to take it's tole.
First thing to check is your t-stat...what temp is it rated for?
Something in the 190/195 range should give you great heat all winter long if the rest of the system is up to par.
vtblazer is offline   Reply With Quote
Old 11-12-2009, 01:25 PM   #4
indianpride77
Re: Heater Question
ok great i will look into that. if anything i will just save up and do both the thermostat and heater core at the same time. cause knowing the guy who owned this previously and how i've seen he's taken care of this blazer so far, it's never been touched. by the way my rant for the day. how dumb are people when it comes to taking care of cars in general. i just had to drop 400 on a complete brake job all around. i meanevery piece of the brake system plus inner and outer bearings. and come to find out while doing the brake job they must have had to cut out a stuck wheel seal. and they cut the front spindle. errrrr i hate dumb people lol sry for the rant
Old 11-12-2009, 02:00 PM   #5
Thealien
Thealien's Avatar
Re: Heater Question
The whole cowl heater core area could be filled with debris limiting air flow also.
Old 11-12-2009, 04:38 PM   #6
indianpride77
Re: Heater Question
thanks for that info too. i know i have a little bit of fun ahead of me now lol
Old 11-13-2009, 01:48 AM   #7
old man jimmy
Re: Heater Question
agree with the heater core. But before I went to all that work. (it's not easy) I would check you regulator on the right fenderwell. Make sure you have hot water going through it. They do go out sometimes.
old man jimmy is offline   Reply With Quote
