Old 11-11-2009, 08:17 PM   #1
Matt Man
Matt Man's Avatar
2wd to 4wd dually
i want to know all the steps its gonna take.
truck is a 86 c30 crew cab 454/400.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
Old 11-11-2009, 08:24 PM   #2
shilo
shilo's Avatar
Re: 2wd to 4wd dually
alot. not to be a smart ass but there is a ton of info if you google it or this site. For starters a transfer case and proper adapter and output shaft for your transmission. a dually front axle so you only have one spare tire. a set of leafs or some badass 4-link front suspension. a few holes to be drilled on you frame and a driveshaft. Not too much but definately work.
why do you want to make a 4x4 when your sig says future lowering plans and 18" wheels?
71 swb 4x4, 37" Iroks, t400/205 496
77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20
shilo is offline   Reply With Quote
Old 11-11-2009, 11:20 PM   #3
b454rat
I'm doing this to my truck now, you can search for my s/n and that will give you an idea. There are also couple other builds out there.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-11-2009, 11:30 PM   #4
ghettoluxury
ghettoluxury's Avatar
you can mate a NP205 with the adapter for the 400 directly to your 2wd tranny
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-11-2009, 11:31 PM   #5
2tons of fun
buy drw d60.
buy b52 kit from diy4x.
find whatever trany tcase combo you want.
install.
2tons of fun is offline   Reply With Quote
Old 11-12-2009, 07:55 AM   #6
Add crossmembers,driveshafts,linkage/shifter,exhaust work...
if you find "any" 4wd model in 73-87 era for a donor you`ll be miles ahead.That`s Blazer to 3+3.The 1t axle will bolt up to the rest and all that is the same 10-30 series.
Old 11-12-2009, 10:25 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
What? Only if it had the proper out put shaft, and there are 3 different TH400 output shafts. He might get lucky, but at worst case he'll have to change his output shaft and find the correct adaptor for 205, 208, or 203 case.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-12-2009, 10:26 PM   #8
Dieselwrencher
It is a lot of work, but not all that hard. It can be done. Like already mentioned a donor truck would make it easier on you as well. If you want to retain bud wheels you need a DRW D60 front, or buy billet spacers to bolt on your new 4wd front axle.
Ryan
Old 11-13-2009, 12:55 AM   #9
2tons of fun
and the 2wd th400 that is in his truck is the proper output shaft for the th400 -205 adapter.
Old 11-13-2009, 07:03 AM   #10
ghettoluxury
I have done this about 15 times and never had to change the output shaft.
Old 11-13-2009, 04:10 PM   #11
Dieselwrencher
Ok good deal. Most of the time the 1 ton dually big block 2wd's have the bolt on output yoke. Everyone I have torn apart has I didn't think a 205 would slide on over threads of that out put shaft.
Ryan
Old 11-14-2009, 12:24 AM   #12
2tons of fun
except fo rthe fact that the threads are femal and have no bearing on the spline or ingaugement......
Old 11-14-2009, 12:40 AM   #13
Dieselwrencher
Ok, sorry,good info to know. I didn't realize this shaft would work with the 205 coupler.
Ryan
