Old 11-11-2009, 08:18 PM   #1
coopdeville
upper control arm after a "z"
is there anyone out there that makes a control arm that will clear the steering shaft after a z? im cheap and dont want to spend the money for u joints if i can buy a tubuler a arm.
myspace.com/southtacomaalleyrally
coopdeville is offline   Reply With Quote
Old 11-11-2009, 09:44 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: upper control arm after a "z"
Not that I am aware of. If they did, why would you think it would be cheaper than the u joints?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-11-2009, 10:10 PM   #3
bedsled71
bedsled71's Avatar
notch your upper arm
bedsled71 is offline   Reply With Quote
Old 11-12-2009, 06:29 AM   #4
The Big Green
X2, notch your arm, can't get cheaper than that. Also, I'd highly recommend cutting and aligning you upper bj while your at it.
The Big Green is offline   Reply With Quote
Old 11-12-2009, 11:29 AM   #5
AVS_JASON
AIRBAGPARTS.COM
AVS_JASON's Avatar
Local guy made these for his personal ride...
AVS_JASON is offline   Reply With Quote
Old 11-12-2009, 11:57 AM   #6
coopdeville
i wouldnt think they would be cheaper... but they would alow more lift and add to the cool factor!
what are you guys using to notch the arm?
Old 11-12-2009, 12:06 PM   #7
bedsled71
bedsled71's Avatar
cut some tube in half
Old 11-12-2009, 12:40 PM   #8
indawaitinroom
yeah id notch the arm. im in the same situation except my trucks stock floored to the doors. my steering shaft looks like it could fit UNDER my upper arm. haha.
i like the one avs jason posted.
indawaitinroom is offline   Reply With Quote
Old 11-12-2009, 12:48 PM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
Don't you still need one u-joint even with the control arm notched?
Articles-
"Refining Sierra"
Old 11-12-2009, 01:34 PM   #10
coopdeville
what size and thickness on tube?
Old 11-12-2009, 01:34 PM   #11
coopdeville
i sure would like a set of those ones in the pic!
Old 11-12-2009, 02:29 PM   #12
The Big Green
I didn't do anything to my steering.
Old 11-12-2009, 08:48 PM   #13
bedsled71
bedsled71's Avatar
i didnt need any either
Old 11-13-2009, 08:52 AM   #14
HotRodYJ
HotRodYJ's Avatar
Use U-joints from junkyard steering systems instead of buying the expensive new ones. I'm running a rack instead, but I built my steering shaft from a couple of old shafts. Took 15 minutes and didn't cost a penny.
66 Chevy Stepside tandem project
My junk: http://67-72chevytrucks.com/vboard/s...d.php?t=480902
HotRodYJ is offline   Reply With Quote
Old 11-13-2009, 09:04 AM   #15
scotts62
One day...
scotts62's Avatar
Cool! You have some pics?
Scott
93 crew cab build
Project 62
Old 11-14-2009, 12:23 PM   #16
Slammed '87
Slammed '87's Avatar
Heres a stock control arm notched out. Looks good imo and serves it's purpose.
If you can't rock the roads with your bumpers 1/2" off the ground, you're nowhere near low enough!
Slammed '87 is offline   Reply With Quote
