11-11-2009, 09:40 PM | #1 |
Air bag size?
Hey guys, i am wondering something, what size of air bags are you running on the front of your truck, i want to use the 8" on the rear, and thinking same or 7" for the front. Thankyou. James
James 1968 GMC "HAVOC" 1986 GMC "Frank" J.J.R.H. Design & Consulting My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300 A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238 1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361 Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390 Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100 1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587 |
11-11-2009, 09:46 PM | #2 |
Texas Big Wig
Re: Air bag size?
Unless you have a C30 & plan on towing a 8" bag is too big for the rear
On the front, a 7" bag is what is commonly used & I havent had any problems with my Slam Specialties RE-7s In the rear, I had a set of RE-7s & replaced them with a RE-6 equivalent, cuz the 7's were just too big for the job... Not that there isnt enough room just over kill & I was having to run really low pressure in them for them to be at the correct hight |
11-11-2009, 09:48 PM | #3 |
low n' slo
Re: Air bag size?
dominator 2600 (8") front and rear...havent rode on them yet but they get some really good lift
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
11-11-2009, 09:58 PM | #4 | |
Re: Air bag size?
Thanks, just curious about pressures now i guess, for front and rear at normal ride height, of bags.
11-11-2009, 11:08 PM | #5 | |
Re: Air bag size?
When I started re-vamping the suspension, I swapped to 6's so I could utilize more pressure @ the same ride height.
11-12-2009, 02:19 AM | #6 |
Re: Air bag size?
slam RE-7 front & rear, 70psi up front 30 out back
11-12-2009, 06:37 AM | #7 |
Re: Air bag size?
If you run Doms 2600 bag front then get ready to start cutting the stock lowers, these are massive bags. They ride great and get great lift for big wheels. Slams get 3in compressed, 11.5in inflated, while Doms get 2.7, and tower in at 13in inflated.
