Old 11-11-2009, 10:33 PM   #1
zac
zac's Avatar
16.5 inch wheels
I'm not seeing alot of tire options for these wheels. It's basically down to 9.50r16.5LT or 33x12.50's. Am I missing something? How about going to 16's to give me more options? Will they fit the rear drums on a 8-lug FF 14 bolt? Thanks.
zac is offline   Reply With Quote
Old 11-11-2009, 11:17 PM   #2
b454rat
Re: 16.5 inch wheels
You can fit 15" wheels on a 14ff. 16" wheels were factory on 3/4 and 1 ton trucks in the 80s, maybe even the late 70s....
Interco still makes alot of tires for 16.5" wheels.
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 11-11-2009, 11:26 PM   #3
ghettoluxury
ghettoluxury's Avatar
16.5 tires are becoming obsolite and like b454rat said a 15" rim will fit the rear but to clear the front calipers be prepared to do a little grinding. 16" rims will clear without any problems at all and 17" rims cost a little more but the tires are usualy cheeper than the 16"
1949 Five Window, 1973 Step Side, 2000 Z71
ghettoluxury is offline   Reply With Quote
Old 11-11-2009, 11:29 PM   #4
2tons of fun
thats funny that you say 16.5 are BECOMING obsolite. ive been told that for 15yrs, and there are more to pick from now than before.
what are you looking for?
2tons of fun is offline   Reply With Quote
Old 11-11-2009, 11:31 PM   #5
cobinder
Everything is work in progress
cobinder's Avatar
It's all a tire/wheel industry game. Whatever you have will be out dated in 4 years. Soon they'll have 16-3/4" wheels just to f**k with us. it's stupid!!
Good luck with your truck!
How much?! It's just an old truck part!!
49 International on a 80 GMC 3/4ton 4x4 chassis
48 International KB-5 2 ton dump bed
04 Honda CRF "500"
09 Honda CRF450 fuel injected rocket
03 Suzuki hayabusa carbonfiber wheeled monster.
02 Ford diesel stretch van (toy hauler)
01 38' Monaco diesel pusher motorhome
cobinder is offline   Reply With Quote
Old 11-11-2009, 11:35 PM   #6
zac
zac's Avatar
I have a set of 33x12.50's on I'm guessing 10" aluminum rims and some 9.50's on the stock rims. Both sets are worn out. I want something in between. How about some 31 or 32x10.50's?
Old 11-12-2009, 07:45 AM   #7
For 2wd street tires the choices are narrowed down to the 9.50 and 12.50.they cut out the 10.00 and 11.00 when the 12.00 went to 12.50/33.I ran the 9.50s on 8.25s up front and the 12.50s on 9.75s on the rear of my Custom Camper.It was the look I wanted to throw back to the style of the era.But,a 10-11" wide tire would have been a nice option.I couldn`t consider lowering with that combo,not that I wanted to.I guess mounted on an 8.25" rim would work for a lowered truck.We never used that narrow of a rim with that wide of a tire back in the day.But,it seems to be acceptable now.
Old 11-12-2009, 10:25 AM   #8
Burt4x4
Burt4x4's Avatar
16.5 Wheels suck for airing down unless you have bead lock wheels, like H1s
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 11-12-2009, 10:33 PM   #9
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
16.5's don't like it on the pulling track either. The bead area is too small.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 11-13-2009, 02:36 AM   #10
OldCreek
OldCreek's Avatar
Do 16.5"s like towing heavy loads?
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold
1972 C10 5.3L/4L60E 12bolt 5Lug - Sold
1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!!
1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold
1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70!!! (Sold)
2003 K2500HD 8.1/Allison1000/NP263
OldCreek is offline   Reply With Quote
Old 11-13-2009, 08:58 AM   #11
I`ve run 16.5s or decades with no problems.I never rock crawled or pulled a weight transfer sled,though.I`ve aired down or sand and that`s it.No problems on sand,but that was all pretty calm driving,too.No roostertails.
Old 11-13-2009, 12:00 PM   #12
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Yup, that was their purpose back in the day, on 3/4T and 1T trucks... typically 6PR or 8PR, sometimes more. Check the maximum load ratings to be sure. As posted above, they don't air down well (to very low pressures) for a couple reasons -- they are often a stiff, heavy tire instead of a flotation tire. But mainly because many 16.5" rims (especially aftermarket) lack the "safety bead" that virtually all other rim sizes have.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-13-2009, 04:04 PM   #13
Dieselwrencher
I have pulled a lot of heavy loads with 16.5's and haven't had a problem.
Ryan
Old 11-13-2009, 06:59 PM   #14
zac
zac's Avatar
I've seen a few options in larger tire sizes but down at my boring "stock height with road gears" end of the spectrum, 9.50's and 33x12.50 seem like the only realistic option. The stock steel wheels seem to be about 8.5" wide. So some 9.50's would probably be OK. They would be around 31", so with 3.42 gears, a TH 400, and I guess a 454 (per the other thread), that might be a good combo. I like this truck just fine, but it is Krylon satin gray and will be used for ocassional car hauler pulling, along with hauling god knows what else (barn wood, field stone, engines, firewood, etc.). I just need this one to work decent so I can get on with the '72 K10 Burb and the '61 K10 lwb Apache projects. Anyone have some specific tire suggestions?
Old 11-14-2009, 07:20 AM   #15
I have some General tires in 9.50-16.5.They may still make those.The stock rims are 6.5 or 7" bead to bead.I`m thinking 7".
Old 11-14-2009, 08:33 AM   #16
Dooley
Dooley's Avatar
During the years that GM had the 16.5" as the stock wheels I always ordered the optional 16" tube type on my trucks.
Dooley is offline   Reply With Quote
Old 11-14-2009, 11:32 AM   #17
16s will go right on there.16s are made in metric sizes in various profiles.235/85-16s are about stock size.You can get 8" rims and run 4 matching or go with 10" rear rims and wider tires.you can get wide tires that aren`t as tall,like on 1/2t trucks and cars.
