Old 11-11-2009, 11:47 PM   #1
1970CustomC10350
Slider switch on acc. pedal?
Hello everyone! I was poking around under the dash checking some wiring on our 71 3/4 ton tonight and noticed some kind of slider switch attached to the acc. pedal linkage. It has two wires running to it. One comes from the fuse box and the other goes out to the engine compartment through the firewall. I'm wondering if it was some kind of cruise control or something like that. Any ideas?
The truck was originally a big block with fac. air if that matters.
Also does anyone make a replacement throttle control that mount to the instrument cluster? I'm pretty sure all I need is the knob. Thanks!
1970CustomC10350 is offline   Reply With Quote
Old 11-12-2009, 12:02 AM   #2
westofb
I really hate wet sanding!
westofb's Avatar
Re: Slider switch on acc. pedal?
I think the sliding switch on the accelerator bracket is actually the kick down for the trans, being a big block probably had a th400 trans. I don't understand your second question, do you mean a choke cable?
westofb is offline   Reply With Quote
Old 11-12-2009, 12:36 AM   #3
1970CustomC10350
Kick down for the transmission. That makes sense, I didn't think of that. It has a 4spd. in it now. I suppose it could have been a choke at one time. O.K. theres a knob directly below the wiper switch. It has a cable like a choke cable but it attaches to the accelerator pedal linkage instead of a choke.
Old 11-12-2009, 01:04 AM   #4
brothers69c-10
Suburban Hick
brothers69c-10's Avatar
Sounds like what we call redneck cruise control
Mathew
1947 Chevy 3600
1951 GMC 100
1969 Chevy C-10 396/500hp TH400 lowered 4"
1968 Imapla Custom 396/325hp TH400 "Grandmas Car"
1976 Crew Cab 4x4 diesel http://67-72chevytrucks.com/vboard/s...d.php?t=488505
1978 Chevy K-10 454
1983 S10 4x4 "Bumblb" (Grandpa's truck)
1993 Chevy S10 V8 conversion
1990 Ford Probe Gt
1992 Dodge W-150 "Old Man's Truck"
1992 Pontiac Grand Prix SE
1992 Mercury Grand Marquis-Mercruiser
2000 Ford F150 (Currently my mother drives this)
1946 Farmall H with Stan Hoist loader
1965 John Deere 110
1961 Wheel Horse " Rat Tractor"
brothers69c-10 is offline   Reply With Quote
Old 11-12-2009, 01:21 AM   #5
highperf4x4
yeah that's supposed to be a choke cable.
And the switch beside the accelerator is a kick down switch for a th400
highperf4x4 is offline   Reply With Quote
Old 11-12-2009, 10:02 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
if that cable is hooked to the throttle, then it is simply a throttle knob. It was used for PTO driven items, or to hold the RPM's up when you needed to charge the truck and/or for running AUX heaters plumbed into the cooling systems. These types of items were semi-common back in the day, and aimed to the camper market.
This was alsso a factory option, but not advertised in all books or literature.
Manual chokes were gone after 68 on these trucks.
Old 11-12-2009, 05:27 PM   #7
1970CustomC10350
Thanks for the info guys. Longhorn Man do you think its factory? I think the truck may have been used for a camper at one time. I thought if I could get it working it would be handy for cold mornings. I wonder if I could use parts from one of the earlier choke setups. This one is missing the knob and shoved in or is broken off flush with the gauge cluster. I'll have to do some checking.
