11-12-2009, 02:17 AM | #1 |
What options are their for OBA for Vortec LS motors.
I have looked around a bit and only found side mount York kits that look terrible. I have a 2005 5.3 truck vortec that I want to add engine driven On Board Air to for faster and quieter tank filling. I am working on figuring out a set up but wanted to see what the options might be.
Thanks for any pics or info. Kevin LFD Inc. |
11-12-2009, 02:13 PM | #2 |
Re: What options are their for OBA for Vortec LS motors.
i believe that a few companies, including qwik performance, make a sanden mount for these motors
11-12-2009, 04:18 PM | #3 |
I may be completely wrong here, but I don't think sanden compressors lend themselves to OBA systems very well due to the oiling/lube requirements.
11-12-2009, 04:19 PM | #4 |
seems like there are work arounds
http://www.s10forum.com/forum/f125/o...thread-215865/ |
11-12-2009, 07:59 PM | #5 |
Ed thanks for the links I will read up the the oiling system they are using. I have also seen that bracket as well as one for a york but I was not impressed with the look. I am sure it works fine but I wanted a tighter stockish look.
So after about 8 hours here is were I am with my set up. I still have some bracing to do on my comp once my 10mx170 bolts come in. It is a tight but good fit. Basically I just remounted the ALT. over were the tensioner was and then mounted a A/C comp I had from my rock crawler over were the ALT. was. Kevin LFD Inc. [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] [IMG][/IMG] |
11-12-2009, 09:35 PM | #6 |
Happy to be here
I was tempted to ask why you wanted something prefabbed knowing your capability to do it yourself.
11-12-2009, 09:48 PM | #7 | |
Kevin LFD Inc. Last edited by Rokcrln; 11-12-2009 at 09:49 PM. |
11-13-2009, 08:42 AM | #8 |
Happy to be here
Aaah, got ya. Everything I have ever seen for OBA has been rather industrial looking.
Are you considering designing a clean system for the LSx and market it?
11-13-2009, 10:59 AM | #9 |
If not..... he prob is now .
11-13-2009, 12:01 PM | #10 | |
Looks to be a good kit for the price and is designed for street rod guys who need to move their A/C up out of the frame. These LSx motors use a separate system for their factory A/C compressor so this kit would just be an adder for air psi.http://www.kwikperf.com/lsx_ac.html Kevin LFD Inc. |
05-18-2014, 01:07 PM | #11 |
i realize this is very old thread but did you ever get it hooked up and running?
1992 Gmc 2wd 1972 Chevy Blazer 2wd |
05-20-2014, 09:24 AM | #12 |
c10 Chop Artist
littleshopmfg.com has a pretty nice setup available
65 c10 build http://67-72chevytrucks.com/vboard/s...d.php?t=467433 68 c10 on 22's (sold it) http://67-72chevytrucks.com/vboard/s...d.php?t=303594 |
