Old 11-12-2009, 09:16 AM   #1
rtracin
steering box on 71 4x4
will the steering box from a 75 4x4 fit on a 71 4x4?
are there any other changes that need made ?
rtracin is offline   Reply With Quote
Old 11-12-2009, 08:43 PM   #2
JimKshortstep4x4
Re: steering box on 71 4x4
Welcome to the 67-72 Chevy Truck Board from West Michigan!
The 75 will bolt up with no mods. I believe that it was not until 79 that they changed the fittings.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 11-12-2009, 09:52 PM   #3
wildwilly4x4
I used the one off an '86 just so I could have the new fittings. Bolt patterns are the same.
wildwilly4x4 is offline   Reply With Quote
Old 11-13-2009, 09:20 AM   #4
rtracin
thanks that helps!
Old 11-13-2009, 11:25 AM   #5
Burt4x4
Burt4x4's Avatar
Hmmm, I thought the "spline" count on the male end of the steering box changed in 73?
I could be confussed that has been happening alot lately...
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 11-13-2009, 11:51 AM   #6
Mudder
Mudder's Avatar
I have also seen different splines for that shaft.
Mudder is offline   Reply With Quote
Old 11-13-2009, 01:27 PM   #7
wildwilly4x4
Just use the ends that go to the steering box you are gonna use.
