Old 11-12-2009, 02:32 PM   #1
csa daddy
csa daddy's Avatar
10 bolt ball joint an 44 ball joint
my ? is i got an 87 gmc jimmy wit new ball joint in it an i got a dana 44 but it needs new ball joints can i take the spindle an all of the 10 bolt an bolt it to the 44 cause the 44 is set up wit 4:56 gears
csa daddy is offline   Reply With Quote
Old 11-12-2009, 03:48 PM   #2
CUSTOM/10
CUSTOM/10's Avatar
Re: 10 bolt ball joint an 44 ball joint
I believe you can but you have to swap everything, including the spindle out to the locking hub, and check axle stub shaft spline count to make sure that is the same. I believe it is, just the long part of the axle splines are differant.
( If my memory serves me right )
Gary
Gary
72 SWB 4x4
My 72 SWB Build
http://67-72chevytrucks.com/vboard/s...d.php?t=259859
CUSTOM/10 is offline   Reply With Quote
Old 11-12-2009, 10:43 PM   #3
csa daddy
csa daddy's Avatar
right i wasnt to worried about the axle shafts they will work just wasnt sure about the ball joints
