01-20-2003, 07:50 PM | #1 |
New Knock
I HAVE A KNOCK STARTING THIS MORNING THAT I DIDN'T HAVE YESTERDAY. IT IS REALLY LOUD AND SOUNDS LIKE ITS ON THE DRIVERS SIDE MAYBE UNDER THE VALVE COVER. BUT NOT YOUR TYPICAL PING OR KNOCK. LIKE A BANGING. RIGHT OUT OF THE OH S--- BOOK HUH. ANY IDEAS OTHER THAN WORSE CASE?
72 CHEYENNE 3/4 TON 4X4...14 bolt full float rear.4.10 gear and 350/350/np205 has a little needs a lot! |
01-20-2003, 07:56 PM | #2 |
Hey im havin the same problem..its in my inline six 292..im not giving up yet though..im gonna change the oil and put lucus in it...hopefully will help
01-20-2003, 07:57 PM | #3 |
but mine is more of the typical knock
01-20-2003, 07:58 PM | #4 |
MINES MOSTLY AROUND 1000 RPM ABOVE IS JUST RANDOM.
01-20-2003, 08:00 PM | #5 |
Hmm mine sorta stops when i rev it up a little..but this truck hadnt been run in like 3 yrs..so maybe it will lossen up
01-20-2003, 08:09 PM | #6 |
IT COULD BE A ROD KNOCK THOUGH COULDN'T IT? THATS EXPENSIVE ...........ISN'T IT?
01-20-2003, 08:47 PM | #7 |
Could be a loose or broken rocker pull the valve cover and check them out might be a cheap fix and then again it might not
Kman
New 89 chevy 1500 driver 72K20 rust bucket project stripped down to the frame engine rebuild started 71 Blazer - another procect |
01-20-2003, 10:13 PM | #8 |
i hope it is the cheap fix..i dont know alot about motors..i just sorta started workin on stuff...im only 15...but im gonna see if it doesnt loosen up...and yes if its the rod knockin that will be expensive..
01-20-2003, 10:44 PM | #9 |
IF IT IS A ROD KNOCK DO I REPLACE JUST BEARINGS OR DO I HAVE TO DO IT ALL?????
01-20-2003, 10:46 PM | #10 |
Someon told me that if u catch it in time that u can just change the bearings...i dont know if this is true...
01-20-2003, 10:48 PM | #11 |
Hey i just saw u were from branson..im close to branson..so if u ever have any parts for sale..contact me and maybe u wont have to ship..just an idea..
01-20-2003, 10:58 PM | #12 |
WILL DO
