Correct Fluids
Can someone tell me the correct gear oil and amount for the NP205 and the proper power steering fluid (tranny fluid)?
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
Workin to live...
Re: Correct Fluids
Jason |
Re: Correct Fluids
It takes 80 - 90 gear lub. As far as how much. Don't really know. Just crawl under their, pull the top plug, and fill till it starts to run out the hole. Put the plug back in. Hopefully you can get under it without jacking it up. You want to do it with the truck half way level.
![]() Join Date: Dec 2002
Re: Correct Fluids
My father a Mechanic dating back to the 50's told me to pull the plug and stick your pinky to the first digit. It should touch that. I have seen Mechanics that a small allen wrench and use that. Same principal
