I have a 1967 c10 lwb, I want to cut the frame down to swb and have been looking around and have seen it done two ways. The first was to cut 12 inches out of the frame right behind the cab, this way you have to remove the rear end and all suspenion components and then try to get it all put back in. The second way was to cut the 12 inches out of the frame under the cab, then just slide the frame back together and weld. I have all the measurments to do it the first way but cant find any real info on where to cut under the cab. Does any one have info?
Grandpa in the rustmobile...
Re: frame cutting
its in the faq..
its a total of 20" 12" in front of rear wheels 8 behind rear wheels... its in the faq section..go to the bottom of this page, they'll be a 'forum jump' go to faq and look around...
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
member #16
![]() Join Date: Dec 1999
Re: frame cutting
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 11-12-2009 at 06:28 PM. |
Re: frame cutting
I cut mine right behind the cab, 12" square cut. It will be boxed for about 8" on wither side of the splice. Once you get to looking at it closer, you will be able to use the hole for the bed mounts to get it lined back up. Extremely easy to do if your not scared to do some cutting and welding. I have done alot of trucks cut like this, even an '86 crewcab 2wd that I made into a crewcab shortbed 4x4. I cut the frame in front of the cab and the rear. Just make sure you brace up the splice areas. I rockcrawl my toys and use them to hunt with also, so they take a beating. Alot of people will say you have to do some crazy angled cuts and diamond shaped splice plates, but that isnt really needed, unless you arent confident in your welding skills. Here is a pic of my '72 longbed diesel that I cut into a short stepper.
