Alernator help/question
So my truck has recently become my daily driver due to my 2000 Impala's trans going boooom
![]() So what do you guys suggest? What alt are you running with what accessories?
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless |
Re: Alernator help/question
bueller... bueller... bueller... bueller...
60-66 Nut
![]() ![]() Join Date: Mar 2007
IIRC my Suburban has a 68 amp alternator. I do run electric fans but stock halogen headlights. I haven't had any issues, but I've been thinking of upgrading to a little bigger Alternator as it seems to be marginal. Have you considered upgrading to at least a 10 or 12si Alternator? What about checking the wrecking yards for a good used one to get you by for a while?
#4 | |
Thank you Captainfab for your help!
1964 Chevy C10 a.k.a. Julie Ann H.E.I. cause its better to be pointless Last edited by BMSJaX; 11-13-2009 at 02:02 AM. |
Junior Member
Don't forget to follow some of the threads about converting from external to internal regulator.
1966 Chevy C10 Longbed I'm Bob....ol Curt was my Grandpa The truck was his and he sure as heck wouldn't understand why I took a perfectly good truck and tore it down! ![]() |
Intentionally Left Blank
If the problem still persists, that when you idle up the engine the volts go up, try switching the pulley to a smaller one. Some of the alternators had different size pulleys and wouldn't excite under x-amount of RPMs at the alternator. The smaller pulley would give you more alternator RPMs without changing the idle setting at the carb. Hope this helps.
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
Resistance is Futile
Be sure to get the V-belt pulley. You can have them change it at the store if it is for the serp set-up.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Ok so i looked at the thread on wiring it in, the only problem is I have an aftermarket wiring harness and the thread and other sources say I need the resistance wire and/or warning light. I do not have either of these... Any idea as to what I need to do in order to make this work??
You can hide a warning light under the dash somewhere. I rewired mine about 20 years ago to go with an internal regulator and had the light as a resister. About a month ago I installed new Autometer gauges and just eliminated the light and have had no problems so far. I don't know why it works, but it does.
#10 | |
Originally I just used the "generator" light that was in the dash. Now I don't have a light at all. No resistor either. I think the theory is that the light will act as a resistor when you kill the power at the ignition switch (when you turn the truck off). The light will come on and burn off the electrical signal that will back feed through the wiring harness and keep the truck from turning off. In some cases the truck will keep running if you don't have a light or a resistor. I can't explain why my truck now doesn't need one. I have an HEI ignition with a big Autometer tach. Maybe the tach acts as a resistor or the HEI needs more power to keep going than the backfeed will allow. You can use a light like in the picture. They're found under the dash of just about every GM I've seen from the 70's and 80's. Sometimes they're well hidden though. They used them as under dash lighting when the doors were open.
They have some pretty slick guys on here that maybe able to explain it better than me.
