Still plays with trucks
transfer case options
My 78 K20 currently runs an SM465 and an NP205 with 5.13 gears.
My knees are shot and I need to convert it to an automatic. I have been looking for a T-400 NP205 setup for the last year with no luck. I am on a pretty tight budget so buying a new adapter and input shaft for my NP205 and doing the machine work to the case to convert it is not likely to happen. I would like to run a T-400. What are my transfer case options? I am new to the 4x4 arena. I know the NP205 is very tough. How do the NP241C and NP208C compare? I know they have aluminum cases but I don't know how strong they are as far as power handling ability or how they compare to each other. I assume the T-400 versions only came in the 3/4-ton and 1-tons. Are there any other newer transfer cases that were available with passenger side drop? Any input would be appreciated.
miSSed opportunity - ground up creation of an AWD 1994 454 SS that never was http://67-72chevytrucks.com/vboard/s...d.php?t=795577 69 C10 shortbed stepside 400 small block - built like what a super sport truck could have been 69 K20 lwb TBI 350 4L60E NP208 14-bolt Dana-44 w/disc 68 Camaro SS / RS 500hp 439 inch roller cam big block 4L80E 79 Malibu TPI 350 4L60 w/ Z28 steering & sway bars |
Re: transfer case options
i got a np205 with a figure 8 bolt pattern with a 27 spline input i will let go you could put it behind a 350 turbo or a 700r4
BlahBlahBlah
I think Wes ClassicHearbeat on the board has a turbo 400 np205 set up for sale.
My thoughts were this was the way to go for strength. But I was talking with Mark Livrat about it and he's run the turbo 350 np205 set up in his big block 4x4 for many years with no problems. |
i ran a 454, turbo 400 and 208 with 44" tires and never had a problem. t-400s and 208s are alot cheaper than a 400/205 combo
71 swb 4x4, 37" Iroks, t400/205 496 77 CJ-7, Narrowed Dana 60 Lockrite, 14 Bolt Spool, 4.56 gears, 39.5" boggers. 360 t-18/d20 |
I have never had a problem out of a 208. If you do run a 208 you get lower gear ratio, 2.6:1 rather than the 1.96:1 that the 205 has.
![]() 1949 Five Window, 1973 Step Side, 2000 Z71 |
#6 | |
What year range will I find an NP208 with passenger side drop? Once I get the transfer case situation figured out and get all the automatic conversion parts I will put in the T-400 and all the matching parts to get the truck back on the road. I have most of the parts I need to do a TBI conversion and also have a 4L80E that will go in as part of that swap but I need to get the automatic conversion done first so it is not so painful to drive the truck.
#7 | |
#8 | |
Both have the small 80mm input bearing and would require complete tear down of the TC, machine work to enlarge the bearing area to 90mm and a new T-400 input shaft & bearing kit. Not really in my budget at this point in time.
member
I put a built up 700r4. You are kinda getting a rebate on the price everytime you stop for gas. The ratio is about .7 to 1 instead of a 1 to 1 ratio with the 350 or 400. I believe that in about 10,000 miles, it will pay for itself. Plus 1st gear is lower than either of the other trans as well.
1967 C/K10 Chevy Panel 1968 C/K20 Chevy Pickup 1968 C/K10 Chevy Suburban 1941 Chevy Sedan Delivery 1960 Chevy Sedan Delivery 1972 Camaro SS 396 #s matching 1971 Harley FX Superglide Last edited by olblue60@aol.com; 11-13-2009 at 12:56 PM. |
#10 | |
I do very little freeway driving and a lot of stop & go so the T-400 not having OD won't really bother me much. I really need the automatic more than anything. With the 5.13 gears and a manual trans I am shifting on average 150 times in a round trip to work and back through town. Not really good on a pair of bad knees to use a heavy truck clutch that often. The SM465 is in need of a rebuild too with all the shifting it has done so I might as well save the rebuild money and put it towards the automatic conversion instead. I will be looking for an 81 to 88 NP208 with a T-400 so I can use the TC components with the 4L80E swap down the road. I will still keep my eye out for a T-400 splined NP205 but they are pretty hard to come by up here used. Nobody wants to get rid of them.
#11 | |
That is what I am looking for just not 3000 miles away. Thanks for the offer.
#13 |
my bad didnt realize how far ya was
#14 |
The CUCV's, ex-military 4x4 Chevy's have the T400/208 setup. There are a few pickups/chassis cabs that have the T400/205 but, they are not as common as the 208 setup. The M1009 Blazer has the T400/208 as standard equipment.
My M1008 has the T400/208. Last edited by Dooley; 11-14-2009 at 08:48 AM. Reason: added info. |
#15 |
The 88-91 NP241c will also work and it has the electric speedo.
