Old 11-12-2009, 11:40 PM   #1
srsummers
Looking for a secondary VIN on a 1955 (2nd series)
My farther in-law bought a 55 last weekend and the cab Vin plate is very faded and dosen't appear to match. I have heard the the 55-59 cars have a secondary vin on the frame under the drivers seat. Do the trucks?
srsummers is offline   Reply With Quote
Old 11-12-2009, 11:45 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: Looking for a secondary VIN on a 1955 (2nd series)
It is usually located on the left rail top anywhere from the radiator support to under the cab.
dwcsr is offline   Reply With Quote
Old 11-13-2009, 12:24 AM   #3
Tri5Nerd
Tripple Five Fanatic
Tri5Nerd's Avatar
Mine is located on the drivers side under the cab.
Look under the cab to see if there is any numbers there. A trick to get all the numbers is to take regular tape about 6" long and overlap 2 pieces of tape then lay it on the frame, make sure the frame has a little dust or dirt on it then rub on the tape and peel and you should have the numbers without too much trouble.
Tri5
1955 Chevy Stepside/LS1 drive train
http://67-72chevytrucks.com/vboard/s...d.php?t=371513
Tri5Nerd is offline   Reply With Quote
Old 11-13-2009, 01:13 AM   #4
OrrieG
OrrieG's Avatar
My 59 has one on the top drivers side frame rail right behind the front crossmember. I found a second on the top drivers side frame fail under the cab. Most cars have a secondary one that is hard to get to to "erase" in case someone would want to conceal the history. I hand sanded my frame to bare metal and did not find any more.
OrrieG is offline   Reply With Quote
