11-13-2009, 09:35 AM | #1 |
Tail Lights won't Turn Off
My rear, red brake lights won't turn off. I checked all up under the brake pedal to see if the switch was stuck, but I either don't know where it is or I just can't get to it. I followed the brake pedal in there DEEP with a flashlight, but never could figure out where the switch would be.
Do you have and ideas on how to stop this? Right now, I'm just pulling the fuse so that it doesn't drain the battery when I'm parked. |
11-13-2009, 10:02 AM | #2 |
Robert Olson Transport
Re: Tail Lights won't Turn Off
the brake light switch should be a plastic kind of plunger switch near the top of the brake pedal. you should be able to see it real easy from the floor looking up if you lay on the floor
11-13-2009, 10:34 AM | #3 |
Once you find it, the fix may be as easy as just readjusting the switch.
If it's the plunger type you may be able to slip the switch (housing) forward/aft in it's mounting to get the correct adjustment. k
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
11-13-2009, 12:25 PM | #4 |
One shot, one kill.
Brake lamp switch adjustment is simple once you find the switch. Push the brake pedal down by hand then simply push the brake light switch forward towards the firewall (it will make a scraping noise as it moves) then release the brake pedal and pull it up towards the seat. It will make that noise again, now it's adjusted properly. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
