Old 11-13-2009, 12:36 PM   #1
coggonobrien
what's it take to remove the fenders
what's the bare minimum i would have to do to get the fenders removed so I can pull my cab? Its a 68 c20. does the front bumper, headlights, grill, inner fenders need to come off?
Thanks for all the help.
David
coggonobrien is offline   Reply With Quote
Old 11-13-2009, 12:53 PM   #2
kyull67
kyull67's Avatar
Re: what's it take to remove the fenders
It's actually easier to pull everything at once. Just unbolt the fenders and take off the whole front clip. you can probably leave the bumper on.
kyull67 is offline   Reply With Quote
Old 11-13-2009, 12:55 PM   #3
coggonobrien
where am i looking for bolts on this besides the rear of the fenders? I'm assuming i gotta unhook the inner fenders
Old 11-13-2009, 01:41 PM   #4
kyull67
kyull67's Avatar
yes inner fenders and down by the rocker panel from the backside of the fender. then unbolt the bottom of the grill and everything should lift off. Or you could leave the inner fenders attached(that's what I do)there's only a few holding those to the cab.
Old 11-13-2009, 01:47 PM   #5
coggonobrien
sounds good thanks for the help
Old 11-13-2009, 02:00 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
You have to also take off the wipers, to take off the cowl, and then you can access the top fender bolts.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-13-2009, 02:09 PM   #7
coggonobrien
what's it take to pop off the wipers? set screw?
Old 11-13-2009, 02:16 PM   #8
67ChevyRedneck
There's a little clip that holds them on. I usually use a pair of vice grips next to the bulb at the end, put a cloth between the wiper and vice grips, and if you wiggle back and forth gently and pull, they usually come off pretty easy.
Jesse James
Project "On a Dime"
Old 11-13-2009, 02:19 PM   #9
cdowns
cdowns's Avatar
you might just want to do something about the wire harness
Old 11-13-2009, 02:31 PM   #10
coggonobrien
harness was cobbled when i got the truck so i just figured on cutting and replacing with an aftermarket complete kit. i will mark both ends of wires though when i cut just in case
Old 11-13-2009, 05:29 PM   #11
tim21391
tim21391's Avatar
i just yanked on my wipers and they came off
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
