11-13-2009, 03:34 PM | #1 |
Proportioning Valve Rebuild?
Is it possible to disassemble and rebuild one of these are are they pretty much fool proof from the get go?
Was doing a final check before going to get my truck inspected today and found my parking brake wasn't working correctly. Never used it since I picked it up so I never noticed it. Tried bleeding the brakes but got no fluid out of the rears... hit the proportioning valve with a test light and it lit up so the valve is "popped". Cracked open the fronts, and closed the rears and pumped the brakes but I cannot get the valve to reset. Do they generally go bad over time or should I begin digging into the rear brakes more to see if there is some other problem? Not seeing any fluid leaks anywhere at the rear wheels. Figured I would ask before tearing stuff down even more. Thanks
1983 C20 - "Project Do It Myself" |
11-13-2009, 04:38 PM | #2 |
Dually Pride
Re: Proportioning Valve Rebuild?
been there done that!
i wouldn't rebuild the proportioning valve, they're just stubborn sometimes and wont reset. you might need to have someone hold the button on the proportioning valve while you pump the brakes to get it to re-center
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
11-13-2009, 11:19 PM | #3 |
check this one out man cheap too...
http://www.classicchevy.com/product....LL-_-20-32-_-X
"Dennis the Menace" 1978 Silverado (2wd, 1/2 ton, short bed)complete nut & bolt frame off restomod LQ9/4L80E MY LS SWAP/FRAME OFF BUILD BOOK 2006 TBSS way too much to list |
11-14-2009, 01:30 AM | #4 |
wait so this is currently happening on mine also all you do is push that button? any help same thing no leaks front will bleed but rear wont and I traced the line all the way back
73 Chevy k10 In progress http://67-72chevytrucks.com/vboard/s...52#post3552552 2000 Trans Am, ls1, 6 Spd http://ls1tech.com/forums/appearance...years-old.html |
11-14-2009, 02:21 AM | #5 |
At the body shop.
You can also manually push the pop over valve back. A major pain in the keister tho
" That didnt make it any newer " " Dont antique the equipment " |
11-14-2009, 10:33 AM | #6 |
Dually Pride
i wouldn't buy the prop valve listed above, GM was dumb about changing it from year to year, things might not line up, and thread sizes will be different, learned that the hard way
11-14-2009, 11:51 AM | #7 |
i guess i got lucky on mine. worked perfectly.
11-14-2009, 09:14 PM | #8 |
How would I go about moving the valve back over manually? Really want/need to get my truck back on the road for some projects I want to get done but I can't get it inspected with this issue o.0
Would rather not replace it if I don't have too. Thanks
11-14-2009, 11:48 PM | #9 |
can it be removed?? im thinking about removing mine!!
11-15-2009, 01:04 AM | #10 |
At the body shop.
Ill see if i can take pics its kinda buried... but their is a nut facing the passenger side pull that off and with a small screwdriver push it towards the driver side. I fought the back brakes for a year on my pile that finally made them bleed, BTW i let them gravity bleed afterwards
11-15-2009, 03:02 AM | #11 |
what does the prop have to do with the ebrake?
yes ou can take it out completely but why would you? they are a semi reduntant saftey feature. why would you rebuild it when they are free at the junk yard? sometimes they just crap out and wont reset. i had one sieze after 6 months sitting, worked perfect before. |
11-15-2009, 11:03 AM | #12 |
as far as taking one out of a junk yard !! i would hate to remove one and then install it to find it as bad as one in the truck to start with!!as far as removing it completely ive had cars in the past that didnt have one from factory !!
i brought a booster and master off a 84 2wd to install my 78 after i fitted it i found out there is a number of different boosters and masters that why im stuck on what wrong with my trucks front brakes i simply dont have any fuild to the calipers |
11-15-2009, 04:00 PM | #13 |
found out what was wrong with mine both hoses where colapsed
11-15-2009, 10:18 PM | #14 |
Slugish
Where is this valve located . Is it down on frame between lower radiator & engine ?
11-15-2009, 10:48 PM | #15 | |
11-16-2009, 12:39 AM | #16 |
i was thinking the same thing!!! until i pictured/remembered the brake fluid running down my legs and soaking my pants... ask me how i know
