Old 11-13-2009, 04:08 PM   #1
Danimal610
No Power Anywhere
I've recently rewired a Chevy C-10 66 pick-up, problem is that I don't have any power anywhere. I followed the instructions perfectly, but still no power.
Can someone help me out, I really need it.
Danimal610 is offline   Reply With Quote
Old 11-13-2009, 04:49 PM   #2
markeb01
Senior Enthusiast
markeb01's Avatar
Re: No Power Anywhere
Did you use a kit, and if so what brand - or is it an original style wire loom? Is the battery charged up, and all fuses in place, etc. More details will help more members offer help.
Old 11-13-2009, 06:28 PM   #3
Roadhammer
Roadhammer's Avatar
I know very little and im in the process of a complete rewire...im using a rebel wire kit...
I would say you need a multimeter or a test light. Start at the battery then work your way arround...the power stops somewhere.
Also no ground=no power...
Jory
Roadhammer is offline   Reply With Quote
Old 11-13-2009, 07:29 PM   #4
padresag
what do they use for the main connector at the firewall. if that is not together all the way that is the feeling that you will get
as Roady says -grounds
battery grounds to eng. eng grounds to body and body to frame
ron
padresag is offline   Reply With Quote
