11-13-2009, 05:01 PM | #1 |
Java Mechanic
Feeling dense...
How in the ding dong do you get the lower ball joints out of 77 LCAs?
Mostly -- which direction do you press them? Seems like it should be simple, but I'm not making any progress.
Keith 11 Lincoln MKT -- Momma's wagon 13 G37xS -- middle age crazy car 68 C20 Fleetside -- RIP Decorating the whole town up at a cost of $27 .... |
11-13-2009, 06:33 PM | #2 |
Grandpa in the rustmobile...
Re: Feeling dense...
1-soak in pb blaster
2-get pickle fork and biggest sledge you own 3-i have some 5 ft prybar, it helped alot 4-if you have a torch, and these balljoints wont be needed again, go for it lol A combo of these did the trick for me (except for the torch, i dont own one)
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
11-13-2009, 06:40 PM | #3 |
a pickle fork nor a torch will do much of anything for you when it come to removing ball joints from the lower control arms.
you will need to press them out ... press from the top of the lca as if you are pushing the ball joint out the bottom of the lca. In other words, with the lca in it's normal orientation, press DOWN. Last edited by Shane; 11-13-2009 at 06:43 PM. |
11-13-2009, 08:29 PM | #4 |
Java Mechanic
Cool, thanks Shane..
crud.. I need to find a bigger receiver cup for my press... :P
11-13-2009, 08:38 PM | #5 |
Junior Member
I just use a 5lb sledge and a couple good blows will knock'em out.
11-13-2009, 09:28 PM | #6 |
One day...
I used to just go to the parts store and rent the puller and then get the cash back once i returned it, (before i bought one) that way you don't F things up with a big hammer, too much heat or kill someone with the pickle fork idea... just a thought.
11-13-2009, 09:42 PM | #7 |
low n' slo
I did the same thing on my tahoe. rented the tool and it made it a breeze. its basically a big ass c clamp and a little piece of pipe that presses it out. was a whole lot easier than the hammer
67 1/2 ton Suburban - Project DRGNWGN. Build thread -_--_--_ _________ _--_-_ -/____|__|__\__ ,.,,,.,.,,.,|_O _______ O_] |
11-14-2009, 06:12 PM | #8 |
Java Mechanic
Got the first one out.. had to cobble up an extra large receiving gup out of a large hole saw and a puller plate because my bearing press didn't have a large enough cup for these.
11-14-2009, 06:47 PM | #9 |
11-14-2009, 09:15 PM | #10 |
Guys, he's asking about pressing them out of the lower control arm ... NOT separating them from the spindle.
11-14-2009, 10:13 PM | #11 |
Junior Member
I've always used a sledge to pop them out of the arm. This method of BJ removal has nothing to do with seperating from the spindle. Don't need any fancy tool or press.
