Old 11-13-2009, 06:22 PM   #1
RALONG
RALONG's Avatar
hard top re sealing problem
Ok i have replaced all the gaskets but the one in the front seams to be to thick so the top will not go forowad enough to seal the windows top needs to come forward more ANY SUGGESTIONS?
RALONG is offline   Reply With Quote
Old 11-13-2009, 10:45 PM   #2
NuBomb
NuBomb's Avatar
Re: hard top re sealing problem
You've probably already tried this, but maybe loosen the small brackets on the window frame to let them out to meet the hard top. I had to do this and then tighten the brackets alternating side to side. If it won't reach maybe put the brackets on the hardtop and then use screws that are too long to just get it started.
Jeremy (NUBOMB)
72K5 CST 350/350/205
1951 Chevy 1/2 ton
North Georgia Group
"... And the first rule to being a man is you gotta spend your life doing crap you don't wanna do." Red Forman.
NuBomb is offline   Reply With Quote
Old 11-14-2009, 01:57 AM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
You've just got to keep working it. I had similar problems – i took a while to get it bolted down after replacing the seals.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 11-14-2009, 01:11 PM   #4
truckster
truckster's Avatar
I put the rear bolts in first (the ones that bolt to the side where the tailgate closes). That gave me a place to put some leverage on the front. Then I loosened the bolts on the two center front brackets to where there were only a couple of turns holding them in. I used a drift to pull the brackets (and the top) down until I could get the longer bolts into the sun visor brackets.
No matter what you do, it's a fight to get the top on tight when you replace the seals. Good luck.
truckster is offline   Reply With Quote
Old 11-14-2009, 03:31 PM   #5
RALONG
RALONG's Avatar
thanks i know it will just be a struggle to get every thing right.
Old 11-14-2009, 11:44 PM   #6
Sacramento70
Blazer Fanatic
Sacramento70's Avatar
my tops never even been off
1970 Chevy blazer
Sacramento70 is offline   Reply With Quote
Old 11-15-2009, 09:01 PM   #7
RALONG
RALONG's Avatar
Yes i bought my 71 blazer in Carson City and lived in Jackson so i can under stand why i live in southeast texas lots of rain.
