Factory upper a arm washers, not the shims
Does anyone have a picture of the factory washers that went on before the shims for alignment. I can't remember if there were two for each side or just one. and if it was one, did it just go on the forward most bolt.
(by the way, 1972 c -10) thanks, dan |
Moderator
![]() Join Date: May 2007
Re: Factory upper a arm washers, not the shims
There is one on each bolt. i just re-built mine.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
I'm referring to the ones between the a arm shaft and the frame
There are two washers per side. One washer on each bolt. The convex side will face the frame.
sweet thanks!
Moderator
Those are the ones I am referring to as well. Is there an echo in here?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 11-14-2009 at 11:23 AM. |
Oops sorry. How about this one, other than the concave washers, are there any other spacers between the concave washers and the shafts?
#8 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 11-15-2009 at 01:33 PM. |
Cool thanks man, if I get time I'll snap a pic of the washers that have me confused and bothered. I was under the impression that these might go on the fore most shaft to straighten the arm considering the frame is at an angle on that portion of the truck.
I've always put the concave side next to the arm shaft, with the shims in back of them.
