It's hard to see what I'm doing up in there...I'm trying to remove the cluster without damaging it. Do I need a special tool to remove each knob first, or can I pull it out as one unit?
Thanks!
www.vancerutherford.com |
Intentionally Left Blank
Re: Another dumb question - how to remove instrument cluster?
You have to remove the knobs. One of them, I think it's the choke, has a piece of metal from the dash that the assembly goes through. I just used needle nosed pliers to undo the nuts on each switch.
1965 C-10 Short Fleet 468/TKO 5-Speed 2004 2500HD Crew 496/Ally Blacked Out (SOLD!!) 1997 Formula WS6 2004 Jeep Wrangler (Sold) 2013 Jeep Wrangler (Sold) 2017 Jeep Wrangler (Blacked Out on 35's) 2011 GMC D-Max Dually Denali 3500HD (Sold) 2015 GMC D-Max Dually Denali 3500HD (Sold) 2018 GMC D-Max Dually Denali 3500HD (Sold) 2020 D-Max Dually Denali on 33x12.50's 1979 GMC Short Bed Step-Side 4x4 350/350 Low Miles |
Don't forget the headllight switch has that button to push in on the side of the switch that you push in as you are pulling the knob and shaft out. You'll have to reach up under the dash to get to it. I then use a BIG washer to fit in the slot to unscrew the retainer on the front of the dash that is holding the switch to it.
Members i've met: LiLRed66 |
You did not say what year your truck is... but this should help.
-W Installing a Tach in a '64-66 Chevy Truck some pictures of my '65 c10 cluster taken apart |
That helps alot, guys. Thanks!!
And Woogeroo, mine is a '66, so those links were right on.
