![]() Join Date: Aug 2008
Rally Wheel Question......
Here is the deal, I want to do like Big Al did on his recent wheel change (stagger rallys, with 15x7 up front). I found one rally which I thought was a 15x7, but it measures 6.5" inside bead to inside bead, with a 4" BS. How many different rallys were made? I've seen some on ebay that are 7" inside to inside, but they have a 4.5" BS. I'm just trying to tuck the fronts a little more so I can drop it another inch. Thanks in advance.
Nick "Everyone has a plan, 'till they get punched in the mouth".........Mike Tyson 1968, GMC, SWB, Project 1972, GMC, LWB, Daily Driver, 383, headers, 2.5"/3" exhaust, 200r4, 3.5/5 ECE components. 1972, C/10, LWB, 350 vortec, th350 |
Re: Rally Wheel Question......
Hey Nick
I dont know about the measurements or how many different ones are out there but I remember reading about just using two van rallies up front and two truck rallies in the back. Remember that I am trying to trade two van rallies for two truck rallies just in case you want to trade. The ones I sent you before are 15x8...
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Active Member
![]() Join Date: Jun 2002
I stand corrected. rim width is measured from inside bead. appologize for bad info.
1969 C10 350 3spd 1995 GMC 3500 XC 350 dually When Thomas Edison worked late into the night on the electric light, he had to do it by gas lamp or candle. I'm sure it made the work seem that much more urgent. George Carlin Last edited by Zeke; 11-15-2009 at 10:28 AM. Reason: incorrect information |
laying low
![]() Join Date: Mar 2001
Sorry Zeke. That's not correct. The industry method of measuring wheel widths is inside bead to inside bead.
This from Coker's site for instance: http://resources.coker.com/wheel-tec...rim-width.html
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Redefining LowBudget
ok the biq queston is how many holes in your rallies...I thnk I went thru this about a month ago.. heres a pic of my 8" rally I have not SEEn A 7" with this amount of holes...some have more some less....I have 8 of these rims and would gladly swap a couple for a couple 7"
Roadtrip!
![]() Join Date: Feb 2003
Rims are measured from the inside of the beads. I believe there is a 6.5", 7" and 8". The 8" were generally on trucks from 73 and up.
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
#7 | ||
[quote=Boog;3619682]Sorry Zeke. That's not correct. The industry method of measuring wheel widths is inside bead to inside bead. That is what I thought I remember reading somewhere, that is how I've been measuring them. Quote:
I definitely have a 6.5" wheel then, Is that a truck rally or a van rally or was there a difference? I ask because of the differences in the backspacing I'm running into.
Moderator
![]() Join Date: May 2007
Van rallyes are 6.5" wide. Truck rallyes are 7" or 8" wide. The size should be stamped on the inside of the wheel.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 11-14-2009 at 12:52 PM. |
Sweet.
Never Ending Projects
Sorry for the hijack.
Are the trim rings used on the 8" ralleys the same for the 7" ones or do the 7" ones have a narrower trim ring?
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#11 | |
Moderator
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man Last edited by leddzepp; 11-14-2009 at 03:00 PM. |
I dun gradjiated collij!!!
Kinda like this, its on the drum side of the wheel usually under an inch of brake dust and grime.
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! Last edited by screamin_c10; 11-15-2009 at 06:06 AM. |
#13 | |
Watch out for your cornhole !
![]() Join Date: Jun 2003
#14 | |
Thanks for the info!!!
#15 | |
Jeff
1970 C10 CST fleetside 472 ....big dreams little cash... SunShine Syndicate.. ![]() Mikes Sandwich Fair Run OCT 8th 2011
#16 |
67-72 parts collector,…
![]() Join Date: Nov 2002
There are 2 different style ralleys.
5-lug 15x6.5 (van ralleys) 15x7 15x8 6-lug (like hottrucks has in his picture) 99% of them are 15x8 They do make a 6-lug 15x7,... but they are rare.
#17 | |
Thanks for asking though.
#18 | |
Tot Roddin'
And a comparison shot of the 15x8 6-lug wheel...
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
#19 | ||
Nate I found the measurement stamp on the back of the wheel, it reads 7", but when I measure the wheel like you did in the pic it measures 6.5" between the beads. I guess that is what a 7" wheel measures.
#20 | |
The 6.5 wheels have a different offset than the 7's. Which wheel are you looking for?
#21 |
Lolife, I am looking for another wheel like the one I have already. I was just trying to ed-u-macate myself on these suckers so I could continue to shop with confidence. I'll post a pic real quick like. Thanks bro!
#22 |
#23 |
That's a 6.5" van ralley.
If you are unsure,... just do all your shopping with a tape measure.
Keith Convert to disc brakes. http://67-72chevytrucks.com/vboard/s...d.php?t=444823 Last edited by lolife99; 11-16-2009 at 12:50 AM. |
#24 |
Thanks lolife, that is what I figured I would have to do to get a matching wheel. I hope this will tuck it a little more like I want.
#25 |
I have 6-lug rallies that I believe are 15x7 front and 15x8 rear. Tires are mounted so determining exact width is difficult, however the back spacing (well, "front" spacing) is noticeably different and the rear tires are pretty effin large. Mine are 5 hole - they look more like the car wheels. I'm currently looking for trim rings and it seems like the fronts need 2 1/2 inch deep rings and the rears 3 1/2 inch. I can find 2 1/2, but not 3 1/2. I could be measuring wrong. Pics of the truck are here http://chevy.jeromio.com. Can anyone clarify? What's the proper way to measure for the correct ring size?
