Cruise control suggestions
I am in the planning stages of an LS 5.3 swap (engine on the way). It is a drive by wire 2005 which makes adding cruise control easy, just a few wires to connect to some switches.
I am looking for suggestions on either a turn signal stalk with the set/accel/coast switches and wires I could replace my directional stalk with (or connect/weld to my original). I am even open to something I could mount on the dash, console? Come on you creative people. I know some of you have just the idea I am looking for. |
Re: Cruise control suggestions
Check this bang-up job that the PO did on my Longhorn -
'67 SWB Fleetside ZZ4/350/Tremec 5-speed/4link/Scott's IFS - and fun as heck! SOLD ![]() Click here to support the board Philippians 4: 6-7 |
Now that's creative!!!!!!!
Kerry My build thread. http://67-72chevytrucks.com/vboard/s....php?p=3657823 1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears 1988 Chev Extendacab 2010 Honda VT1300CS Sabre 2005 Buick Rendezvous wife's ride |
![]() Join Date: Feb 2001
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
I don't need anything to control the cruise. The PCM from the 5.3 LS engine will do that. I need an no/off switch with the 3 momentary set/accel/coast switches for the turn signal lever. Dakota digital does have some switches they include with their kit that look like what I am looking for, I wonder if they will sell them seperately?
HND-1 - Universal Cutoff Handle - Secures to existing turn signal handle shaft. HND-2 - Dash Mount Switch - Can be secured to or under dash for hidden operation. Unit Meaures 2" wide by 1-3/8" high HND-3 - Replacement GM Handle - Secures with single screw through flat end. HND-4 - GM "Push In" Handle - For most post '80 GM columns without Wiper Controls. |
I used this handle and bolted it right in for my Rostra CC set up in my 70. For my 72 Tahoe I will be using the same switch for my 2005 5.3L D.B.W as well.
You can buy just the handle but I could not find it quickly. http://www.summitracing.com/parts/FL...4/?image=large Kevin LFD Inc. |
That is exactly what I am looking for! If you should happen to find just that handle listed somewhere or find a part number please keep me in mind. If I get to the point I need it I guess I could call flaming river or summit.
![]() Join Date: Jan 2007
Make sure you research open vs. closed circuit cruise control circuits. Most of these stalks will NOT work. I'm in the middle of this and ended up buying a push button set up and will mount it on the dash or somewhere else.
1972 K20 Suburban 5.7/700r4/NP205 Dana 44/H052 Sold ![]() 1972 C10 5.3L/4L60E 12bolt 5Lug - Sold ![]() 1971 K5 Blazer 6.0L LQ9 4L60E NP205 Dana 44/H052!!! ![]() 1970 K3500 1ton CrewCab 8.1L/Allison1000/NP205 Dana 60/14B!!!! - Sold ![]() ![]() ![]() 1984 K10 SWB 7.4L/4L80e/NP208 Corp 10/12 bolt Sold ![]() 1988 V30 CCLB 7.4L/TH400/NP205/Dana 60/Dana 70/3.73!!! (Sold) ![]() 2003 K2500HD 8.1/Allison1000/NP263 ![]() |
I'M TRUCK CRAZY!
interesting. I want to know about doing it on a reg old 350.
wait... don't want to hyjack |
![]() Join Date: Apr 2005
I think this is what you need. It's what I'm using on my 06 5.3. Only $40 from Dakota.
http://www.dakotadigital.com/index.c...prod/prd50.htm
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
ok for those of us that are not drive by wire what would you suggest?
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#13 |
is Certifiable
This might work......and it should drop right in.
1972 Chevy C10 LWB 350 Auto Blue with a white roof. |
#14 |
I'M TRUCK CRAZY!
![]() yeah, I don't see any modifications needed |
#15 | |
That's what I'll be using too....have it installed on the column and I'm about to hook it up to the TAC box. |
#16 | |
Where are you getting the pins for the TAC box or are you connecting to the factory wires from the donor truck? |
#17 | |
bbadfred
![]() Join Date: Mar 2008
which push button setup and how did you wire it? I have a rostra switch and cannot get it to work |
#18 | |
the boat guy
The brick idea might be a little worse, especially with that turbo. Posted via Mobile Device
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
