Old 11-14-2009, 12:20 PM   #1
chevy88
chevy88's Avatar
Core rad support frame
Can some one tell me the distance between core rad support and frame? This will help in initially lining things up and possibly if I have rubber supports backwards as I wasn't paying attention again when I pulled it apart.
Kerry
My build thread.
http://67-72chevytrucks.com/vboard/s....php?p=3657823
1971 Chev SWB with 68 nose, 6.2 diesel th350, and 3.73 rear gears
1988 Chev Extendacab
2010 Honda VT1300CS Sabre
2005 Buick Rendezvous wife's ride
chevy88 is offline   Reply With Quote
Old 11-14-2009, 05:17 PM   #2
epashhans
epashhans's Avatar
Re: Core rad support frame
Hey K, after looking at yours I believe there are two different setups...if you are going to the 67-68 front end. Check the two setups here...
Mounts
You can see the 60-68 is a different setup...and they have it pictured upside down (at least that is how mine was when I took it apart).
I put an orange line where the rad support will go, and the blue line is where the frame would be. And then on mine, those triangular pieces on the bottom were bent up so the nut could not spin off. Not sure if that was someones personal touch or if that is the way they came. I would guess that is the way its suppose to be.
As a side note, the LMC mag I have shows the setup you have...so I am not sure if it will work with that one or not...? Maybe someone else can chime in.
'67 C-10 Shorty - 454, 5spd, and speed holes!
epashhans is offline   Reply With Quote
Old 11-14-2009, 05:58 PM   #3
seafoam68
seafoam68's Avatar
Wink Re: Core rad support frame
There is a difference in 67,68 and 69-72. The 67,68 have a smaller hole in the frame mount piece and use the mounts with the triangle shaped piece. The LMC catalog is not correct, as they show one mount for all years. Sorry, but mine is all apart right now, so I can't provide the distance between core and mount.
seafoam68 is offline   Reply With Quote
Old 11-14-2009, 09:44 PM   #4
epashhans
epashhans's Avatar
Thats what I thought. Does my diagram with the colored lines look correct?
Mine is all apart as well!
Old 11-14-2009, 10:12 PM   #5
LockDoc
The Older Generation
LockDoc's Avatar
The flat one goes between the core support and frame and the shoulder on it goes down in the hole in the frame mount. The cone shaped one goes on the bottom small end down.
You have them reversed....
LockDoc
Leon
Old 11-14-2009, 11:04 PM   #6
westofb
I really hate wet sanding!
westofb's Avatar
LockDoc
I agree you have the rubbers reversed!
Jeff,
68 C-10
75 C-20, now a C-10!
10 F-150
westofb is offline   Reply With Quote
Old 11-15-2009, 03:10 AM   #7
epashhans
epashhans's Avatar
LockDoc, do you have a picture of it assembled?...I guess I am not completely clear on what you are saying and would like to know as I am will be putting mine back together soon. I am thinking mine wasn't correct from the PO...so it wouldn't have been correct when I took it apart.
Old 11-15-2009, 08:09 PM   #8
LockDoc
LockDoc's Avatar
I'll see if I can get a pic tomorrow.
LockDoc
Leon
Old 11-16-2009, 04:11 PM   #9
LockDoc
LockDoc's Avatar
This is the best I can do...
LockDoc
Leon
Old 11-16-2009, 04:36 PM   #10
epashhans
epashhans's Avatar
I just looked again this morning and most of it was still rusted to the rad support...so this is how mine went (on my 67) from top to bottom:
Square "washer" goes inside rad support with bolt hanging down.
Then rad support.
Then under rad support, there is a rubber "washer" and two steel "washers".
Then frame.
Then rubber "washer", steel "washer", and then triangular piece, and then nut.
I altered my previous diagram to show this (below).
Not sure if that is correct, but that is the way mine was...and appears to have been for a long time. Rubber was shot...everything else rusted together.
Old 11-16-2009, 04:47 PM   #11
LockDoc
LockDoc's Avatar
Then rad support.
Then frame.
I didn't catch that you had a '67. They are completely different than what is posted in this thread... The OP has a '71 GMC.
LockDoc
Leon
Old 11-16-2009, 08:40 PM   #12
chevy88
chevy88's Avatar
Thanks for all the info/diagrams guys, I got in put on right now and the fenders all lined up good.
Kerry
My build thread.
Old 11-16-2009, 10:34 PM   #13
epashhans
epashhans's Avatar
K, you already got your fenders and front end put on? Dang. How does the 67 clip look on the ol gmc?
Old 11-17-2009, 01:26 AM   #14
chevy88
chevy88's Avatar
It will look a lot better once I get it all painted, but I sure like it better than the all chrome GMC grill.
Kerry
My build thread.
