Old 11-14-2009, 03:28 PM   #1
profe56
3.42 and 3.73
After I take off the rearend cover, how can I find is 3.73 or 3.42?
profe56 is offline   Reply With Quote
Old 11-14-2009, 03:32 PM   #2
cableguy0
Re: 3.42 and 3.73
spin the ring gear until you find the stamp. it will look like this 40:13 it probably wont be those exact numbers. but the bigger number is the ring gear count the smaller the pinion. just divide the ring by the pinion and you have the ratio. you can also count the teeth on the gears and divide the numbers
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 11-14-2009, 03:33 PM   #3
dan76
Re: 3.42 and 3.73
Count the teeth on the pinion/ring gears and divide.
Example: a pinion gear with 10 teeth and a ring gear with 41 teeth = 4.10
dan76 is offline   Reply With Quote
Old 11-14-2009, 03:34 PM   #4
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: 3.42 and 3.73
Look on the ring gear and see if there are numbers stamped in it. This should tell you although you will have to decode it.
If there are no numbers stamped count your teeth on the ring gear then the pinion gear and divide.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
