Old 11-14-2009, 04:34 PM   #1
Sinister
Between Trucks...
Sinister's Avatar
Changing out Shocks
Gonna be changing out the shocks on my '69 C-20, any tips I should be aware of?
Beat it to fit,
Paint it to match...
Sinister is offline   Reply With Quote
Old 11-14-2009, 06:33 PM   #2
scotts62
One day...
scotts62's Avatar
Re: Changing out Shocks
Is it just stock?
Scott
93 crew cab build
Project 62
Old 11-14-2009, 06:37 PM   #3
Sinister
Between Trucks...
Sinister's Avatar
Totally stock.
Beat it to fit,
Old 11-14-2009, 06:45 PM   #4
fiddy9apache
fiddy9apache's Avatar
remove and replace. oh and i would soak down the bolts in PB blaster the day before. and maybe new bolts for when you put the new one on or chase the treads with a die and run a tap through the bolt to clean out dirt and rust.
fiddy9apache is offline   Reply With Quote
Old 11-14-2009, 06:48 PM   #5
scotts62
One day...
scotts62's Avatar
Yup there ya go, you don't have to go and buy the most expensive but i would buy some good ones.
Scott
93 crew cab build
Project 62
Old 11-14-2009, 06:53 PM   #6
Sinister
Between Trucks...
Sinister's Avatar
Sounds good. Just didn't know if I was going to be under the truck fighting to compress the shocks or not. Have a tap and die set so I'm good there. Ordered some KYB Gas a Justs, so looking forward to the new ride quality
Beat it to fit,
Old 11-14-2009, 07:10 PM   #7
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Those white KYBs are stiff. They will come with a band on them holding them compressed. It's easiest to bolt the top mount on, then have the lower bolt ready so when you cut the band and the shocks start to extend, you can control it and get the lower mount pinned into place.
Old 11-14-2009, 08:02 PM   #8
Sinister
Between Trucks...
Sinister's Avatar
Are they too stiff? I really have nothing to go by, original shocks are what's on there now.
Beat it to fit,
Old 11-14-2009, 08:06 PM   #9
scotts62
One day...
scotts62's Avatar
Yeah like what TX firefighter said, you can compress them but let the shock the work and just push a bolt through real quick. Those shocks should do you just fine.
Scott
93 crew cab build
Project 62
Old 11-14-2009, 08:08 PM   #10
Sinister
Between Trucks...
Sinister's Avatar
Cool, thanks guys.
Beat it to fit,
Old 11-14-2009, 08:20 PM   #11
scotts62
One day...
scotts62's Avatar
No problem
Scott
93 crew cab build
Project 62
Old 11-14-2009, 10:10 PM   #12
SCOTI
SCOTI's Avatar
Gas-a-justs are too stiff IMO.... The GR-2's are better suited for our trucks.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 11-15-2009, 07:17 AM   #13
Sinister
Between Trucks...
Sinister's Avatar
Hmmm. The KYB website isn't showing a GR-2 for the rear of a '69 C-20 with coils. Summit is showing a GR-2 for the rear but doesn't say if coils or leafs. Maybe I'll just run GR-2's in the front.
Beat it to fit,
