11-14-2009, 05:39 PM | #1 |
62 drop spindles ??
are there drop spindles to fit a 62 truck but still retain the front drum brakes availiable?? as i dont want the cost of changing to disks at this time
11-14-2009, 06:27 PM | #2 |
Resistance is Futile
Re: 62 drop spindles ??
Not that I'm aware of....I've stared at a few catalogs over the years and never seen any. If you're lowering, you're converting at the same time I guess.
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
11-14-2009, 06:29 PM | #3 |
One day...
Yeah your best bet would be to do a front suspension swap, then you get disc, way cheaper ball joints and drop spindles that are easier to find. Works out all the way around
11-14-2009, 08:22 PM | #4 |
11-14-2009, 08:26 PM | #5 |
One day...
I think they make 6 lug rotors for 73-87... ill have to check around or maybe one of these good fellows will chime in with the correct info. I think i remember seeing a kit from somewhere though.. |
11-15-2009, 12:40 AM | #6 |
60-66 Nut
If you want to stay with 6 lug wheels, there are 2 ways to do it. You can buy aftermarket 6 lug rotors to fit the '73-'87 spindles, or you can do it with OEM parts. Check out this thread for some more info on this.
http://www.67-72chevytrucks.com/vboa...d.php?t=367260
11-15-2009, 01:47 AM | #7 |
There are no aftermarket dropped spindles for drum brakes. You must upgrade to discs, or, use stepped/dropped lower a-arms.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-15-2009 at 01:47 AM. |
11-15-2009, 01:47 AM | #8 | |
11-15-2009, 02:03 AM | #9 |
The easiest way is 73-87 swap w/aftermarket 6-lug 1.25" rotors. Some guys like the slightly more difficult approach using all OE components w/the 88-98 year model stuff. Either way, the coil front is leap years ahead or the torsion bars...... 73-87's offer the more 'pliant' rubber bushings vs. the rubber-lined steel-sleeve 63-72 bushings. 3/4 ton bushings are still rubber-lined steel sleeves from what I've personally seen.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 11-15-2009 at 02:04 AM. |
