Time Machine
![]() Join Date: Oct 2009
Frame cracks?
While cleaning up my frame, I discovered that it has a crack that goes about 1/2 way around the front upper bolt hole for the steering box. any suggestions ont the best way to fix this? Thanks
Re: Frame cracks?
ORD makes a steering reinforcement bracket. I would drill the crack, weld it up and look into the ORD kit.
these are meant for 4WD but I bet you can make it work... or fab something like it. http://www.offroaddesign.com/catalog/steeringkit.htm
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
70 Chevrolet=Obsession
Re: Frame cracks?
Ouch! I agree with Msgross.
![]() ![]() ![]() I'm Just like my truck. Old, Ugly and Grouchy. Except my truck starts easily in the morning and doesn't smoke! IT'S NOT EASY BEING GREEN! -Kermit the frog 1970 Chevrolet C-10 Longbed Stepside : 350, Muncie M20, 3.08 GM corp. positraction Forest green exterior/light green interior(Where all my money goes) 1996 Toyota Corolla (Parts runner) |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: Frame cracks?
Pretty common place for them to crack. I dig the crack out with a grinding wheel and weld it back up.
Re: Frame cracks?
^ This
If you want more insurance throw a fish plate on and weld it as well.
72 k20 Cheyenne Super 350 Turbo 400 Dana 44 Front / 60 Rear NP 208. 315 70 17 Hummer H2 wheels. Black. |
Re: Frame cracks?
Here in Texas it was real common to run 10 inch wide wheels and 295/50s on all 4 corners. I did it myself a few years. I've always blamed that kind of setup on cracking frames behind the box.
Re: Frame cracks?
Admit it . . .... You had a mullit before the professional years!
Re: Frame cracks?
I rocked a Mullet all the way down to my belt in the back. I also drove a 78 Z28 Camaro and listened to Guns and Roses on a Sparkomatic cassette deck with 6x9s in the rear package tray. I was Joe Dirt before Hollywood ever had the idea.
#9 | |
I dun gradjiated collij!!!
Re: Frame cracks?
Built NOT Bought. Viper Red 1971 LWB C10 355 Vortec W/700R4 4/5 drop AKA Screamin' You are missed!
2006 F150 XLT 5.4L Triton Rollin' on 22s the "F1" 67 C20 PS/AC/327/TH400 we call 'er "Bessie" 67 Malibu PS/ZR1-LS1 Brakes/350 Vortec/700R4 2/2 drop on 18" 338s - Tracy's "Boo" Boosted '67 Cougar EFI 5.0 HO roller motor/T5/8.8 Tracloc/ 4 wheel disks - "Project Panther" 79 Honda Z50 - stretched, cafe'd and hotrodded 125CC Lifan/5spd FEAR THE MONKEY! |
Re: Frame cracks?
I knew it.... You had more than one color 'Members Only' jacket too huh?
Time Machine
Re: Frame cracks?
thanks for the input guys
Re: Frame cracks?
No members only jackets for me.
![]() Notice the TX registration sticker is 2005.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 11-15-2009 at 11:09 AM. |
#13 | |
Re: Frame cracks?
When repairing a crack I have learned the way to do it is to drill a hole at the end of the crack.Then weld the hole & crack. |
#14 |
Re: Frame cracks?
+1 on drilling the hole at the end of the crack also known as "stop drilling", that helps keep the crack from starting over again after it is welded up. I'd vee the crack out a bit with the grinder as TXFF said he does to get a good weld on it too.
#15 |
Re: Frame cracks?
Like they are all saying dig it out stop drill and weld it up, fish plate if ya think ya need it, its not a unusual place to crack on chevy trucks..
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() Last edited by UltraBlue71; 11-15-2009 at 01:37 PM. |
#16 |
Time Machine
Re: Frame cracks?
Thanks that's how I'll repair it.
#17 | |
Re: Frame cracks?
IH trucks (especially Scout II's) run a close second as far as favorites for me...
"You can put lipstick on a pig, sure it's pretty pig, but it's still just a PIG... ![]() 71 ![]() |
