Old 01-20-2003, 10:50 PM   #1
69ChevySB
dropped69
High RPMS
Hi there folks, I was wondering what I could do to get lower rpms at higher speeds....when i'm goin down the freeway or highway it sounds like my motor is gonna explode because i'm going like 75 and my rpms is like 3500-4000 at that speed...what can I do to prevent my rpms from going so high? Maybe it's because I have a 3 speed on the floor and it feels as if I need another gear to throw it in...would it make a difference if I put a 4 speed in, or automatic transmission? Thanks.
69ChevySB is offline   Reply With Quote
Old 01-20-2003, 10:58 PM   #2
mooneyes
mooneyes's Avatar
a 4 speed or automatic ( unless an overdrive) wont make a difference..you need either a rearend with higher gears ( numerically lower) or an overdrive tranny
Ken Lyons, Slippery rock pa
68 short step 327 t10 4 gear
72 2wd blazer project
70 lwb 305/700r driver
78 caprice project
02 cavalier D.D ( hate it!!)
mooneyes is offline   Reply With Quote
Old 01-20-2003, 10:59 PM   #3
Truckstr
Truckstr's Avatar
It's the gearing.
The combination of a low (high numerical) rear and 1:1 top gear ratio tranny amount to high RPM at normal highway cruising speeds.
You can change the 'effective' rear gear ratio by going to really tall rear tires, but IMO the only correct way to do it is with a higher (lower numerical) rear gear AND/OR a overdrive tranny.
What's your budget?
Jeff
Jeff
'67 short Fleet; my ongoing project.
'66 long Fleet; my original "baby."
Live life or bust trying.
Truckstr is offline   Reply With Quote
Old 01-21-2003, 12:08 AM   #4
spinning wheels
spinning wheels's Avatar
Try taller tires
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 01-21-2003, 12:22 AM   #5
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Put on a 4 speed shifter knob?
Sorry....
Change the rear axle gear ratio.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
