Old 11-15-2009, 02:06 AM   #1
BenU
BenU's Avatar
Cab corners ?? !!
I am in the process of putting new cab corners into my 69 gmc, i cut the old corner out, but when i went to put the new corner in, it doesn't look right. Where goes from the side to the back, the replacement piece isn't curved as high as the original cab. There isn't a difference in cabs between the 67-72 trucks is there. This is my first rebuild and my first body work project, and i don't know what the heck i am doing. I NEED HELP!!!!!!
Drive it like you stole it!
BenU is offline   Reply With Quote
Old 11-15-2009, 02:13 AM   #2
71blksuper4x4
SWB 4x4 Collector
71blksuper4x4's Avatar
Re: Cab corners ?? !!
There is no difference in the cab corners and rocker panels in 67-72. For the most part they interchange parts. It would help us out to see pics of what you are talking about. Many of us have welded in patch panels over the years, I am a little confused what you mean about the curve isn't as high. Trevor
TREVOR
1970 CST swb 4x4 (speedwarning,cruise,tilt,tach,8track, original red shoulder belts,tow hooks)
1972 Jimmy (soon to be Hickey cloned)
1971 Cheyenne Super 4x4 swb (tilt,tach,buckets, original blue shoulder belts,am/fm,cruise,tow hooks, dealer 8 track)
1972 Cheyenne Super K20 4x4 Custom Camper (tilt, tach, am/fm, tow hooks, bed toolbox, aux gas tank
1972 Cheyenne Super Crew Cab K30 4x4 Duramax, Allison, np205, buckets, tow hooks (CURRENT PROJECT)
http://67-72chevytrucks.com/vboard/s...d.php?t=624819
1989 V3500 Crew Cab (454tbi, NV4500, np205)
1970 Chevelle SS (LS5 454,th400,8track,buckets,tach)
:2004 Jeep Wrangler Rubicon (daily driver)
WTB: 1968-70 Cruise Control Lever
71blksuper4x4 is offline   Reply With Quote
Old 11-15-2009, 10:24 AM   #3
chaosdsr
chaosdsr's Avatar
I have a good idea on what you are dealing with, does the cab corner your using have a red sticker on it? If so I just went through this, those are the cheap chinese ones and are not even close to the original cab corner. Order the corners from anyone who sells keyparts like mgbmike there quality is a ton better and the steel is thicker not to mention the fit is almost exact!
chaosdsr is offline   Reply With Quote
Old 11-15-2009, 11:24 AM   #4
BenU
BenU's Avatar
I bought these cab corners off LMC, but they don't seem to match up at all. The ribs on the back of the cab don't match up either.
Old 11-15-2009, 10:07 PM   #5
kev2809
low n' slo
kev2809's Avatar
gonna be tough to figure out without any pics. i bought a fender cup from brothers, and it fit like crap to be honest. i REALLY had to bend it to make match, it was ridiculous but i got it to work.
67 1/2 ton Suburban - Project DRGNWGN. Build thread
-_--_--_ _________
_--_-_ -/____|__|__\__
,.,,,.,.,,.,|_O _______ O_]
kev2809 is offline   Reply With Quote
