11-15-2009, 06:40 AM | #1 |
HaV0KSR559<~~~
3/6 drop yes or no
on a 69 half ton long bed
should i go with that considering it would be cheaper to do that compared to prices here at the local shops??? and if i was to go with the 3 6 how do you think it will look and who else would have possibly seen it or have it aswell and if so does the frame have to be notch because i hear people talkin about anything over 6 it does and ive also heard anything more than 5 please help... thanks
...1969_CUSTOM_1O
FLEETSIDE_LONGBED V8_THREE-FIFTY [COMPLETE-EDELBROCK] [PERFORMANCE-SERIES] [CAM_CARB_MANIFOLD] ...TURBO-400_TRANNY... |
11-15-2009, 07:59 AM | #2 |
Re: 3/6 drop yes or no
With a 3/6 youll be higher in the front thab the front 3/5 may be better if you want springs only
70 SWB STEPSIDE 70 BLAZER 09 challenger |
11-15-2009, 08:05 AM | #3 |
HaV0KSR559<~~~
well i have the front coils and shocks already but i was comparing some prices and found the 6 inch drop coils...
would it be lower in the rear or would it be a dead on even stance cause i want as less of a rake as possible... if not ill just get the 5 i like the 3 5 i just wanted to get some opinions ya no thanks for your advice
...1969_CUSTOM_1O
11-15-2009, 04:31 PM | #4 |
Tot Roddin'
3.5/5 is about as level as you can get.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
11-15-2009, 04:48 PM | #5 |
You could always go with the 5 drop and then block the rest to what you want...a one inch block to make it 6, two inch for 7???
I ordered a 3/5 and that is what I am going to do if I think its too raked as I like it more level front to back...just a very slight rake.
'67 C-10 Shorty - 454, 5spd, and speed holes! |
11-15-2009, 05:55 PM | #6 |
HaV0KSR559<~~~
ya i like the lift in the back just to where its barely noticable but id rather have it level...
so say i slap the 3 5 n and i want it lower in the back if i put a 1 to 2 in block drop would i have to c notch it??? still stumpt on when you have to notch the rear... thanks a million
...1969_CUSTOM_1O
11-15-2009, 06:02 PM | #7 |
I think it will look good, mine is 3 1/2 front, 6 rear i have a c notch but some say you dont need it.
11-15-2009, 09:26 PM | #8 |
Not sure on the c-notch. I am not going to do mine with a 3/5 for now. I am just going to drive it and see. If it hits the bump stops a lot, I will probably do it. A guy could fab up a c-notch for pretty cheap too if you have a welder. Member see ten used a 4x4 piece of metal...
home made c-notch Looks like it turned out pretty good...and you could probably get that metal at a machine shop for free from their scrap pile. Could probably do it with a big piece of pipe too. Just a thought.
11-27-2009, 12:30 PM | #9 |
HaV0KSR559<~~~
3 5 KIT
...1969_CUSTOM_1O
